18650 cells
rv8iator
PostPosted: Mon Sep 21, 2020 7:24 am    Post subject: 18650 cells Reply with quote
  Regarding 18650 cells... etc.
Bob's relayed test method would identify unqualified 18650 cells...
I purchased a few samples from different suppliers with ratings up to 4500 mAh.   The ones rated at 4500 mah felt lighter in weight than the similar cells rated at 3000 mAh.  A friend designs medical x-ray machines so I asked if he would x-ray one of the light weight cells and one "normal" cell.  Unfortunately I don't have an image to share.  A description will suffice.  The light weight cell housed a much smaller cell.  Hmmm!
Simerly I was replacing the output transistor in a regulated bench power supply.  I recall it was a 2N3055.  I found a "deal" on Ebay.  Five for $5...  Upon receipt I noticed the marking on the case didn't appear quite right.  It was labeled STM... lightly scratching the marking it readily came off.  Hmmm.   Using a Dremel tool with a cut-off wheel I removed the top of the case.  Voila!  A tiny junction with .002" bond wires!  That someone can make a living going to the trouble of counterfeiting transistors!
Caveat Emptor
Chris Stone
C. Stone (RV8iator)
