KIS-List Digest: 3 Msgs - 09/19/20
pastormac62
PostPosted: Sun Sep 20, 2020 5:57 am    Post subject: KIS-List Digest: 3 Msgs - 09/19/20 Reply with quote
Hi,
I would measure out at the end of the wings as well. If one side is off, I would check the two spar bolts that hold the wing in place. There is a sleeve for both bolts and if the bolts are over tightened they can go into the composite and cause a wing to droop.
To our success, Stephen McIntosh
On Sep 20, 2020, at 2:37 AM, KIS-List Digest Server <kis-list(at)matronics.com> wrote:
Today's complete KIS-List Digest can also be found in either of the
of the KIS-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-09-19&Archive=KIS
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-09-19&Archive=KIS
KIS-List Digest Archive
Total Messages Posted Sat 09/19/20: 3
Today's Message Index:
1. 05:58 PM - Can you identify this TR-1 nose gear? (jeffbudner)
2. 06:15 PM - Re: Can you identify this TR-1 nose gear? (Robert Reed)
3. 07:13 PM - Re: Can you identify this TR-1 nose gear? (Graham Brighton)
________________________________ Message 1 _____________________________________
Time: 05:58:27 PM PST US
Subject: Can you identify this TR-1 nose gear?
Hi all, I'm in the midst of a pre-buy inspection for a TR-1, and have a couple
of questions, that hopefully you can help me answer:
1. Posted below are pics of the nose gear assembly, from these pics can you determine
if this is an original model nose gear or a more hardened version?
2. Regarding the flaps, the left flap extends down 1.5" lower than the right. Is
this an adjustment issue or could there be some intentional purpose to it?
My apology is I've posted too many pics, I wasn't sure which pics are relevant
to question 1 above.
Jeff
http://forums.matronics.com/viewtopic.php?p=498455#498455
http://forums.matronics.com//files/img_1484_706.jpg
http://forums.matronics.com//files/img_7770_401.jpg
http://forums.matronics.com//files/img_1048_188.jpg
http://forums.matronics.com//files/img_9845_2_442.jpg
http://forums.matronics.com//files/img_4495_117.jpg
http://forums.matronics.com//files/img_0184_460.jpg
________________________________ Message 2 _____________________________________
Time: 06:15:35 PM PST US
Subject: Re: Can you identify this TR-1 nose gear?
I dont have an answer for you about the TR-1 but your photos look like the gear
on the TR-4. The original gear for the TR-4 was linked to rudder pedals and provided
nose wheel steering. Those were replaced early on with free castering
version.
Bob Reed
Is this an adjustment issue or could there be some intentional purpose to it?
> Thanks,
> Jeff
________________________________ Message 3 _____________________________________
Time: 07:13:25 PM PST US
From: "Graham Brighton" <gbrighton(at)skymesh.com.au>
Hi Jeff,
I fly a TR1 .. Your Nose Gear Leg appears to the Good ... and
appears to be the most recent Hendricks version . I know of 4 versions .
First version was round ( approx 1 inch Dia) formed/shaped .. not strong ...
next 2 versions were 'Airfoil Tube' construction .. and lastly the strongest
Round larger Diameter unit u photo'd .
Regarding Flap extension being 1 and a Half inch different ... that would
alarm me ... a suggest investigate why this is so . !!?? ( they should be
rigged to deploy uniformly together ... and so fly straight and true and
controllable ... departure from 'in unison' Flap Deployment ... introduces
controllability issues/concerns )
Luv my TR1 .. good luck,
Graham
Kit #80
Sent: Sunday, September 20, 2020 10:58 AM
> couple of questions, that hopefully you can help me answer:
> you determine if this is an original model nose gear or a more hardened
> version?
> right. Is this an adjustment issue or could there be some intentional
> purpose to it?
> relevant to question 1 above.
> Thanks,
> Jeff
> This email has been checked for viruses by AVG.
> https://www.avg.com
