Use 1/4" hole on starter for engine ground?
PostPosted: Fri Aug 28, 2020 4:46 am    Post subject: Use 1/4" hole on starter for engine ground? Reply with quote
I’ll seek a UK supplier of welding cable in short lengths to replace the 2 fat cables to the starter. The terminals on my present wires are crimped using a hand hydraulic crimper - would that still be OK for welding cable, or is it important to solder the joints on such wire terminations?
Here's one option:
https://tinyurl.com/y535olwm
Crimp or solder . . . either process
skillfully applied produces the holy
grail of wire termination - gas tightness.
