rparigoris
Posted: Wed Aug 26, 2020 9:45 am Post subject: Use 1/4" hole on starter for engine ground? |
Hi Group I have a Rotax 914 with heavy duty starter. There is a casting at the rear of the starter with an untapped 1/4" hole perhaps 1/2" thick. Is there any reason why I couldn't use this as my only engine ground? I can't use the engine lift point as ground because the wire will interfere with cooling air baffle air flow down and around the B&C SD20S alternator. There is a tapped 6mm hole on the 2 aft cylinders but the starter is closer to the firewall ground pass through. Ron P.
Joined: 28 Mar 2008 Posts: 1910 Location: Riley TWP Michigan
Posted: Wed Aug 26, 2020 2:11 pm Post subject: Re: Use 1/4" hole on starter for engine ground? |
Actually that ground lug on the starter is the ideal location for the engine ground cable.
Current will not have to pass through the engine block to crank the engine.
_________________ Joe Gores |
