Removing a starter on a classic?
ward.t(at)xtra.co.nz
PostPosted: Mon Jul 20, 2020 3:10 pm    Post subject: Removing a starter on a classic? Reply with quote
Hi Pete,
I recall you do to allow enough room for the starter spline to withdraw. Also to get at the top bolt. Have a go first, nothing ventured nothing gained. I have had to replace my starter with the Rotax HD starter as I have the Rotax 912 100hp ULS. Starter too small to start engine during Winter. Had to make a slight alteration to engine frame to accommodate the longer new starter.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton
CHRISTCHURCH 8052
Hom 03315166
On 21/07/2020, at 10:29, Pete <peterz(at)zutrasoft.com> wrote:
For the classic owners out there,
With my engine out, but the mount frame still on the engine, is it possible to remove the starter to give it a service/inspection (while the engine is out)? Or must the engine frame be removed?
Many thanks!
Pete
<image0.jpeg>
