Diodes - Ground Pwr/Battery Master Contactors
PostPosted: Sun Jun 28, 2020 5:24 am    Post subject: Diodes - Ground Pwr/Battery Master Contactors Reply with quote
At 08:04 AM 6/28/2020, you wrote:
Hi - Â This is my first question for the forum. Â
I am building RV8 w single aft battery/ dual alternator. Ground power contactor and battery master battery contactors are aft.  Obtained both contactors from B&C with 1N5400 diodes. Total of 3 diodes  (2  on the Ground Pwr Contactor  and  1 on the Battery Master Contactor.)
Diagram from Aircraft Spruce with the Piper jacks written by AeroElectric  showed using 1N5402 diodes on  the  Ground Pwr contactor. Are there compelling reasons  to  swap out  my 1N5400 diodes with 1N5402 or other?
Thanks for reading and for responding.
The 1N54xx series devices are essentially
identical for our purposes. The XX denotes
reverse voltage rating that range from 50
to 1000 volts. See:
https://www.vishay.com/docs/88516/1n5400.pdf
For our purposes, any of those devices
will be operated within limits on a
14v aircraft.
Drum
PostPosted: Wed Jul 01, 2020 12:47 pm    Post subject: Re: Diodes - Ground Pwr/Battery Master Contactors Reply with quote
Thank you!
Drum G
RV8 - Firewall Forward
Holly Hill, SC
