Current consumption of Facet cube fuel pump
Peter(at)sportingaero.com
PostPosted: Sun Jun 21, 2020 1:52 pm    Post subject: Current consumption of Facet cube fuel pump Reply with quote
Does anyone know the power rating (or current consumption) of a Facet 40105 fuel pump when operating at the low pressure end of its range (3 psi)?
Thanks, Peter
jdubner
PostPosted: Sun Jun 21, 2020 2:22 pm    Post subject: Current consumption of Facet cube fuel pump Reply with quote
Peter,
Can't speak for the "low pressure end of its range" but I measured mine drawing
1.4A at 14V in a Long-EZ. Fed with 20 AWG wire and protected by a 5A fuse.
Joe
Independence, OR
Peter Pengilly wrote on 6/21/2020 14:46:
Thanks, Peter
Independence, OR
echristley(at)att.net
PostPosted: Wed Jun 24, 2020 6:03 am    Post subject: Current consumption of Facet cube fuel pump Reply with quote
From the product description:
Facet fuel pumps have low power requirements (about 1 amp at 12 volts)
On Sunday, June 21, 2020, 5:53:03 PM EDT, Peter Pengilly <peter(at)sportingaero.com> wrote:
Thanks, Peter
glastar(at)gmx.net
PostPosted: Wed Jun 24, 2020 12:00 pm    Post subject: Current consumption of Facet cube fuel pump Reply with quote
I had them once measured on a 12V battery with 0.9A continouse and peak 1.2A
Cheers
psi)?
Thanks, Peter
