Physical construction of Z101 engine bus & battery bus
PostPosted: Sun Jun 07, 2020 12:33 pm    Post subject: Physical construction of Z101 engine bus & battery bus Reply with quote
At 11:41 AM 6/7/2020, you wrote:
Thanks for the replies. I was not aware of the 9" minimum length on fusible links. Is that somewhere in the Connection?
not yet but will be called out on Z101's notes . . . and probably
as 6" minimum.
Are crimped butt connectors adequate for connecting the fusible link to the protected wire?
Yes
I recently received some of this fusible link wire in both 12 & 14 gauge. Anyone have experience with it?
Used on millions of cars for decades. Will be
testing here on the bench and recording the
results. Crimped or soldered joints will, I
trust, prove satisfactory. There is nothing
magic about the wire . . . it's the insulation
that makes it special.
