Z101 has been released under Rev A (Robert L. Nuckolls, II
PostPosted: Sun May 31, 2020 7:05 pm    Post subject: Z101 has been released under Rev A (Robert L. Nuckolls, II Reply with quote
At 05:14 PM 5/28/2020, you wrote:
Quick question on this diagram:Â Near the upper left, there is a feed coming off of the battery bus that is labeled for a 30A fused feed to "BOBUS". Is that correct? I see two feeds coming into to the brownout / CD bus: 1 from the diode bridge that feeds the engine bus, and one (switched) directly from the battery side of the battery contactor.Â
Thanks!Â
Good eye . . . that's an artifact of
an earlier iteration. I've continued to
massage the concepts illustrated in the
new z-figure.
New iteration will be posted soon. Thanks
for checking!
