Shelf life of electrical components in humid and dry envir
PostPosted: Mon May 25, 2020 2:09 pm    Post subject: Shelf life of electrical components in humid and dry envir Reply with quote
At 02:24 PM 5/25/2020, you wrote:
--> AeroElectric-List message posted by: Dan <limadelta(at)gmail.com>
Hi all,
I am completing my Lancair ES, finally! I am finalizing wiring that was planned 15 years ago! I chose Z-14, Bob’s dual electric system, planning two 17 AH batteries in the rear of the airplane, and I acquired all the components years ago. I installed the battery contactors and a ground power contactor in the rear of the airplane and ran all the wiring required from the rear to the front years ago. The components in the airplane sat in a pretty humid environment, and other components said in boxes in a dryer environment. My question is whether I need to worry about shelf life of any of these components. For example, if the contactors test OK, are they good to go, or should I replace them? Generally, what components in Z-14, if any, would be susceptible to degradation from sitting?
I don't think you have anything to be worried about.
