crimp multiple wires into one terminal
PostPosted: Fri May 15, 2020 11:05 am    Post subject: crimp multiple wires into one terminal Reply with quote
Interestingly, Jeff was speaking with a jet aircraft repair technician who mentioned the solder pellet method of attaching a fat wire to a fat lug. This fellow recommended from his experience to crimp after soldering.
I cannot imagine why. Solder or crimp (if done with
skill and process) are independently sufficient.
Mashing on a well flowed solder joint with
a crimp tool doesn't make sense to me. Was
the speaker alluding to failures of the solder-
only devices?
