Monowheel Brake Caliper Piston
Franzgo
PostPosted: Wed Jan 15, 2020 3:12 am    Post subject: Monowheel Brake Caliper Piston Reply with quote
Hi All,
On a classic monowheel my caliper piston is a bit corroded and even with a good cleaning and polishing, after 20 years of service it would need to be replaced... As you know Europa Aircraft ltd. no longer provides any parts for the monowheel system...
However, I have read in an old post that "The Europa caliper is a clone of the Cleveland"
Has anyone checked if the Cleveland pistons (p/n 79-00300) are the same of the Europa mono ? Spruce Aircraft does not provide any dimensions about this piston and I have neither find any information from Cleveland.
The Europa monowheel caliper piston measures 1''3/4 in diameter (44,5mm)
Thanks for your contribution,
François
Europa MonoW 914
Isère, France
Franzgo
