		bobbypaulk(at)comcast.net Guest
				 Posted: Sat Jan 04, 2020 5:39 pm    Post subject: Master switch alarm |
				As a forgetful  ole geezer I leave the high intensity strobes on when out to a fly-in or the $100 hamburger and turn them off with the Master switch. You won't walk away from your plane without seeing them.  You can turn them off before the next start.
        Back at home port I turn them off with the panel  switch.
        Bobby
		echristley(at)att.net Guest
				 Posted: Sun Jan 05, 2020 9:39 am    Post subject: Master switch alarm |
				My master requires a key.  I have the key on the same ring as my house key.  The only way I can leave the switch  on is to leave the key in it, which I will know as soon as I'm not able to get in the house
        On Saturday, January 4, 2020, 8:39:37 PM EST, Bobby Paulk <bobbypaulk(at)comcast.net> wrote:
        Bobby
				 Posted: Tue Jan 07, 2020 7:53 am    Post subject: Master switch alarm |
				At 11:37 AM 1/5/2020, you wrote:
   	  | Quote: | 	 		  My master requires a key.  I have the key on the same ring as my house key.  The only way I can leave the switch  on is to leave the key in it, which I will know as soon as I'm not able to get in the house
  Bobby  |
    My all time favorite system shut down warning
    is the flashing, low voltage warning light. We used
    to sell a kit that included a high intensity
    led annunciator fixture. The instructions
    suggested that the annunciator be mounted
    in prominent location in front of pilot.
    The FIRST thing you see when the BAT MASTER
    comes on is a red flashing light, the LAST
    thing you see is the same light just before
    the master is turned off.
    This configuration conforms to several
    design goals for system reliability.
    The obvious feature is timely and
    active notification of a low volts
    event. It gets pre and post flight tested on
    every flight. It helps remind the
    pilot to get everything shut
    down before exiting the aircraft.
				 Posted: Tue Jan 07, 2020 9:26 am    Post subject: Master switch alarm |
  Bobby  |
		rv7a.n18pf(at)gmail.com Guest
				 Posted: Tue Jan 07, 2020 11:21 am    Post subject: Master switch alarm |
				I too have a flashing light on the panel to indicate low voltage ("you left the master on stupid!"), however I have still left it on.  I get distracted by someone on the ground as I'm getting out, or bright sunlight washes it out, or I just didn't look - it didn't matter I still left it on!  So I built a small circuit using a PIC and programmed it to start beeping 30 seconds after the bus voltage drops below 13 volts.  I like the audio alarm that only goes off if I take too long to shutdown so I don't get used to it.
 Besides, it was a fun project - education and recreation, just like the FAA says!
 Paul Fisher
 RV-7A N18PF
 Q-200 N17PF
 On Tue, Jan 7, 2020, 11:32 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  On Saturday, January 4, 2020, 8:39:37 PM EST, Bobby Paulk <bobbypaulk(at)comcast.net (bobbypaulk(at)comcast.net)> wrote:
  Bobby  |
