nuckollsr(at)cox.net Guest
Posted: Sun Jun 24, 2007 7:19 pm Post subject: B&C voltage regulator low voltage warning |
At 06:03 AM 6/24/2007 -0700, you wrote:
Quote: |
I have a B&C voltage regulator that controls one of their 60-amp,
12volt alternators. One characteristic of this regulator that has
been there since day one is that immediately upon starting the engine
I get a steady low-voltage light (LED), even though the measured
output voltage is normal. By the time I do a runup and take off the
light goes off. It is a steady light, not the flashing light that
would indicate an actual low voltage condition. I went to a lower
bypass resistor,
??? bypass resistor? Don't know what that is. Oh, you're using
a LED. Try hooking a incandescent lamp up temporarily and see
if that works. The circuit was not originally designed to work
with LEDs. What LED resistor values are you using?
Quote: | but it is still there. Anyone else have the
problem? For now I just ignore it.
What does it do when the engine is running and the
alternator is shut off? Does it come back on steady
or does it flash? I think your resistor values
need to be reviewed.
Deems Davis
Posted: Sun Jun 24, 2007 8:07 pm Post subject: B&C voltage regulator low voltage warning |
I would like to subsitute an LED for the Low Voltage bulb that came with
the B&C LR3C-14 . I posed the question to Tim Hedding (at) B&C and received
this in response.
If you use an LED instead of an incandescent lamp, install a 470 - 510 Ohm,
1/2 Watt, resistor between terminals 3 and 5 of the LR3C-14 (or the SB1B-14)
so that the LED does not glow dimly all of the time.
Deems Davis # 406
Engine / Wiring and Panel Stuff
http://deemsrv10.com/
EricWalker Guest
Posted: Mon Dec 23, 2019 12:37 am Post subject: Re: B&C voltage regulator low voltage warning |
Mechanism of the ruling is deposed for the intelligent individuals. The change of the british assignment writers is brought for the forms for all kids. The role is assigned for the mixing of the laws. Path is issued for the management of the terms. The procedure is allowed for the fitness of the bloggers for the town and its impact for the sizable rules.
johnbright
Joined: 14 Dec 2011 Posts: 165 Location: Newport News, VA
Posted: Mon Dec 23, 2019 7:34 pm Post subject: Re: B&C voltage regulator low voltage warning |
Hi Deems... ref: http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg
Deems Davis wrote: | I would like to subsitute an LED for the Low Voltage bulb that came with
this in response.
Deems Davis # 406
_________________ John Bright, RV-6A, at FWF, O-360
N1921R links |
Posted: Thu Dec 26, 2019 10:12 am Post subject: B&C voltage regulator low voltage warning |
At 09:34 PM 12/23/2019, you wrote:
Quote: | --> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
> this in response.
> so that the LED does not glow dimly all of the time. |
Either of these techniques works . . . in fact,
Tim's suggestion is probably the most elegant.
