Europa mono brake caliper piston o-ring size and type?
peterz(at)zutrasoft.com
PostPosted: Sat Dec 21, 2019 1:56 pm    Post subject: Europa mono brake caliper piston o-ring size and type? Reply with quote
Turns out my rebuild, re-using the one in there doesn’t work....i suspect it currently has a replacement of the wrong size, and doesn’t seal properly.
Thanks!
Pete Smile
C-GNPZ #120
Remi Guerner
PostPosted: Sun Dec 22, 2019 8:23 am    Post subject: Re: Europa mono brake caliper piston o-ring size and type? Reply with quote
Pete,
I replaced mine years ago.
Dimensions: 37.69x3,53 mm (37.69 is internal diameter)
Material: PB851
Supplier: https://www.oring.fr
Remi
PostPosted: Sun Dec 22, 2019 5:32 pm    Post subject: Europa mono brake caliper piston o-ring size and type? Reply with quote
Thx Remi!
I lucked out with a local purchase, with one of a bunch measuring to your spec.
Indeed it fixed my leak Smile
Thx ahain,
Pete
On Dec 22, 2019, at 11:31 AM, Remi Guerner <air.guerner(at)orange.fr> wrote:
Pete,
Material: PB851
Remi
http://forums.matronics.com/viewtopic.php?p=493934#493934
