Airmaster prop upgrade article in EF89
Remi Guerner
PostPosted: Fri Dec 20, 2019 2:44 am    Post subject: Airmaster prop upgrade article in EF89 Reply with quote
This is a question to Bud and Jim.
Hi Guys,
I re-read your very interesting article regarding Whirlwind blade testing on the AP332 hub and need a clarification. In the conclusion, you mention "3200RPM coarse limit setting". Does that mean you get only 3200RPM during a ground run-up at full throttle with the prop in Manual mode and full coarse?
Remi
