Hac-man gen 3 mixture control
creightonious
PostPosted: Thu Dec 12, 2019 3:31 pm    Post subject: Hac-man gen 3 mixture control Reply with quote
I have been using a Hacman for several years at this point. The Bings do a good job of keeping the mixture sweet up to about 4000ft (80hp 912).
On some of my longer legs I have climbed as high as 11500ft and have been able to keep EGTs up and fuel flows down (WOT and 3.5GPH). Obviously I only fly this high in order to ride a smoking tailwind.
The vacuum lines in my kit were aquarium tubing and were not up to engine compartment conditions and had to be replaced with more durable tubing.
I like the Hacman and the addition of a constant speed prop rounds out the package, Affording better climb, faster cruise, and more consistent fuel flows. Consistent rpm reduces my tendency toward fugoid of a hundred or so feet which affects rpm and power.
Creighton Smith A-009
Creighton Smith
A 036
kingsnjan(at)westnet.com.
PostPosted: Sat Dec 14, 2019 4:15 am    Post subject: Hac-man gen 3 mixture control Reply with quote
Creighton,
Like you, I have a 912 (80hp) and a CS prop but as yet, no Hacman. I
fully concur with your statement that the Bings do a good job up to
about 4000 ft and your fuel flow at WOT at altitude of 3.5 GPH is very
much the same as what I get down low on the same power setting.
Your figures are what I would expect at altitude (with leaning) so I am
much encouraged by your experience.
Thank you for your input and I would be interested to know what sort of
tubing you have found to be more reliable please.  If I am reading the
Hacman information correctly, I think they may have changed the tubing
type on their Gen 3 unit.
Best regards
Kingsley Hurst
