Desulfinating trickle charger with Garmin avionics
whodja
PostPosted: Sun Oct 20, 2019 3:31 am    Post subject: Desulfinating trickle charger with Garmin avionics Reply with quote
I use an Odyssey battery charger for my PC680 to maintain the battery. Occasionally I turn on the Garmin avionics while the charger is connected. I recently heard that the desulfurization circuitry is bad for an internal fuse in the avionics. Does anyone know about this?
rngurley(at)att.net
PostPosted: Sun Oct 20, 2019 7:50 am    Post subject: Desulfinating trickle charger with Garmin avionics Reply with quote
http://forums.matronics.com/viewtopic.php?p=491877#491877
jimkale(at)roadrunner.com
PostPosted: Sun Oct 20, 2019 9:07 am    Post subject: Desulfinating trickle charger with Garmin avionics Reply with quote
Most desulfurization circuits send an occasional high voltage spike down the
charger leads. This only lasts for a few milliseconds. However, the high
voltage spike could lead to a couple of milliseconds of high current. This
should not damage most fuse/circuit breakers, however, there might be some
out there that could be damaged.
