Hydraulic mule connections to my L-29
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
transmatch(at)aol.com
PostPosted: Thu Aug 22, 2019 11:58 pm    Post subject: Hydraulic mule connections to my L-29 Reply with quote
Hello all:
I have been attempting to power the hydraulic system of my L-29 from a hydraulic mule. I have connected the high pressure line from the mule to the aft auxiliary connector located at the right aft wing root and identified as Ha-11. This is the smaller of the two connectors that has M16 x 1 threads. The forward connector is the one that is larger (M22 x 1.5) Ha-3. The Album Schematic shows Ha-3 as an out flow but it is ball checked preventing outflow. When I power up the mule, I can extend and retract the Air Brakes (that’s all I’ve had the courage to operate!) but massive amounts of 5606 jets out of the hydraulic over pressure line at the bottom of the fuselage. No matter how low I set the pressure output on the mule, this still happens. The manuals mention a “hydraulic truck” connected to these ports but make no mention of how this is done.
I am VERY confused! Any help will be greatly appreciated.
Gene Freeman
N229DD
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
