Motorglider Wings?
Goto page Previous  1, 2
John Roedseth
PostPosted: Thu May 23, 2019 4:00 am    Post subject: Re: Motorglider Wings? Reply with quote
Hi Pete,
Soaring with the Motorglider works, even on a normal day with medium thermals (2 to 4 m/s). I have a compensated VSI like most gliders. The Europa has a low specific wing loading, and climbs well, but as Ian Cook says it is not so easy. I find the ailerons not efficient enough for tight thermals. Flying slow (+_60 knots) can be challenging in a thermal! I agree with Ian, visibility is not optimal to fly with others in the same thermal. You are better off exploring waves etc. To be honest, if gliding is important, you will be better off joining a gliding club and borrowing a real glider. I use LX-CWT 95% of the time for going places, economically and sometimes throttling back to use lift from thermals on the way. The long wings are additional safety, if the engine should stop for some reason or other. If someone wants a more detailed view of the merits of the motorglider or even meeting somewhere near Luxembourg for a demo flight, send me an email (roedseth(at)pt.lu). Regards, John.
Page 2 of 2
