Weight of new XS cowling
Eddie
PostPosted: Sat Apr 06, 2019 11:14 pm    Post subject: Weight of new XS cowling Reply with quote
Hello All,
I recently ordered a firewall forward kit from Europa which came with a nice new cowling.
The weight of the cowl seems excessive though.
The top cowl is approximately 10 lbs and the bottom cowl is 14 lbs.
They are very thick in places (about 4.2mm where the prop hub opening will be once cut out).
Could some of you please let me know what yours weighed in at?
Eddie
G-SELF classic with XS cockpit module.
Was J3300 powered soon to be 912ULS powered
JohnFrance
PostPosted: Sun Apr 07, 2019 11:03 pm    Post subject: Re: Weight of new XS cowling Reply with quote
Hi Eddie,
You’re absolutely right about the increased weight of the cowlings. I purchased a lower Cowling about two years ago, when ready to install it was 1.6 kg heavier than the original one.
As you mentioned they are considerably thicker than the older model and hence the extra weight.
As an exercise in composite work I am repairing my original cowling and adding a cowl flap and the ULS cooling inlet.
Europa mono Nr 192
Eddie
PostPosted: Mon Apr 08, 2019 9:23 am    Post subject: Re: Weight of new XS cowling Reply with quote
Thanks for your reply John.
I think I need to discuss this with Europa then.
All the best
Eddie
