Loose fitting M10x110 bolts in engine frame MT05
Eddie
PostPosted: Sat Feb 09, 2019 4:05 am    Post subject: Loose fitting M10x110 bolts in engine frame MT05 Reply with quote
Hello All,
I have just purchased a new firewall forward kit from Europa and 912ULS and have a question about the MT05 frame they recently supplied.
The manual shows (p3-1 diagram) that this MT05 frame is bolted to the Rotax ring mount with 4x M10x110 bolts with Binx nuts.
Whilst trial fitting the frame the bolts are really loose in the MT05 tubes. The bolts are about 2mm smaller than the ID of the tubes and there is no washer to spread the load or plug specified to keep the bolts central. Can this really be right?
Also no washer specified to go under the Binx but. Is that right?
Could someone with an older frame please let me know what the ID and OD (or ID and wall thickness) is of the tubes that the M10x110 bolts go through.
When one compares the LG01 attachment tubes there is quite a difference in tolerances.
Ed
Eddie
PostPosted: Wed Feb 13, 2019 7:58 am    Post subject: Re: Loose fitting M10x110 bolts in engine frame MT05 Reply with quote
Have heard back from Europa. Last batch of MT05 frames were made incorrectly. I shall be returning mine to be reworked.
They will also contact the one other owner who has an incorrect frame so to best of my knowledge nobody else should be affected.
Eddie
G-SELF classic with XS cockpit module.
Was J3300 powered soon to be 912ULS powered
