Starter - Ring Gear Selection for Corvair
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
xt_laser(at)yahoo.com
PostPosted: Sat Nov 24, 2018 6:02 am    Post subject: Starter - Ring Gear Selection for Corvair Reply with quote
Hello,
We are in the midst of putting together (2) Corvair engines. I am looking to prepare a detailed documentation package for the modifications we have developed which may be more friendly to builders. More on that later. We are looking for suggestions on the starter and ring gear combinations that we should consider for front/prop mounted starters. The two that are suggested on the web include the Mercury Marine, Ford 3.0L and Nissan 1.6L versions. Does anyone have part numbers/sources etc so we can continue our evaluation?
B-
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
jarheadpilot82
PostPosted: Sat Nov 24, 2018 6:57 am    Post subject: Re: Starter - Ring Gear Selection for Corvair Reply with quote
FYI -
https://flycorvair.net/2017/10/28/old-starter-replacement/
Also, you stated -
"I am looking to prepare a detailed documentation package for the modifications we have developed which may be more friendly to builders."
I am curious. More friendly than what.
Semper Fi,
Terry Hand
Athens, GA
simmor2
PostPosted: Sun Nov 25, 2018 4:25 am    Post subject: Starter - Ring Gear Selection for Corvair Reply with quote
Try this!
These folks have been more than helpful to me.
They have a very simple set up from prop to flywheel.
http://azaleaaviation.com/
- Rich
Flying Zenith with Jabiru
Building a Corvair Piet
FB- Rich’s Piet Build
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
