Adding a Fuse Block
rv6a(at)rogers.com
PostPosted: Fri Nov 23, 2018 6:57 am    Post subject: Adding a Fuse Block Reply with quote
Hi Bob
I have been flying my RV6A for nearly ten years using your Z-11 wiring system.. This system has worked extremely well. I am currentlyin the process of adding a second radio and audio panel, but have run out of useable tabs on my main & endurance busses. I have a “four fuse” fuse block that I would like to add to the main buss. If I mount the extra fuse block within six inches of the main bus, can I power it from the main bus power terminal via an unfused #16 wire? The alternative would be to free up a tab on the main bus, run a fused wire from the tab and then move that consumer to the new fuse block.
Appreciate you advice.
RV6A
PostPosted: Fri Nov 23, 2018 7:46 am    Post subject: Re: Adding a Fuse Block Reply with quote
Yes, that is what I would do. Just make absolutely sure that #16 wire has no chance of shorting out.
Support it well near the terminations and double insulate it if it will help.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Fri Nov 23, 2018 1:59 pm    Post subject: Adding a Fuse Block Reply with quote
Why not use the same size wire that feeds the main bus? 16 ga significantly limits the total carrying capacity of the added bus, and could bite you or future maintainers if a couple of high load devices get added to the new block.
On Nov 23, 2018, at 10:05 AM, John Crate <rv6a(at)rogers.com (rv6a(at)rogers.com)> wrote:
--> AeroElectric-List message posted by: John Crate <rv6a(at)rogers.com>Hi BobI have been flying my RV6A for nearly ten years using your Z-11 wiring system.. This system has worked extremely well. I am currentlyin the process of adding a second radio and audio panel, but have run out of useable tabs on my main & endurance busses. I have a “four fuse” fuse block that I would like to add to the main buss. If I mount the extra fuse block within six inches of the main bus, can I power it from the main bus power terminal via an unfused #16 wire? The alternative would be to free up a tab on the main bus, run a fused wire from the tab and then move that consumer to the new fuse block. Appreciate you advice.Thanks,JohnRV6Ahttp://www>http://www.matronics.com/contribution
PostPosted: Sat Nov 24, 2018 2:33 pm    Post subject: Adding a Fuse Block Reply with quote
Hi Bob
Yes . . . just tie the two busses
together by-the-bolts with a short
pieces of wire. #16 would be okay;
you really won't be tying much load
onto the new bus.
PostPosted: Sat Nov 24, 2018 2:35 pm    Post subject: Adding a Fuse Block Reply with quote
At 03:50 PM 11/23/2018, you wrote:
Why not use the same size wire that feeds the main bus? 16 ga significantly limits the total carrying capacity of the added bus, and could bite you or future maintainers if a couple of high load devices get added to the new block.'
Recall that except for voltage drop
considerations, 22AWG under Tefzel
doesn't get into trouble at 20A.
16AWG is 4x the cross section of 22AWG.
It would be quite sufficient over the
distance cited.
rv6a(at)rogers.com
PostPosted: Mon Nov 26, 2018 4:52 am    Post subject: Adding a Fuse Block Reply with quote
Thanks to all who replied. Much appreciated.
