Connecting rod cyl # 5 is bent, can the cylinder be replaced
ssvoysky(at)gmail.com
PostPosted: Tue Nov 20, 2018 1:10 pm    Post subject: Connecting rod cyl # 5 is bent, can the cylinder be replaced Reply with quote
[img]cid:493629543530097560165148[/img]
 Filesize:  2.95 MB
 Viewed:  2083 Time(s)
migfighter42(at)gmail.com
PostPosted: Tue Nov 20, 2018 1:48 pm    Post subject: Connecting rod cyl # 5 is bent, can the cylinder be replaced Reply with quote
Doesn’t look as bad as mine, but you need to check the crankshaft. At that point, it’s pretty far apart so...
Bill Culberson
Red Star Aero Services
251/716/8119
On Nov 20, 2018, at 3:08 PM, Serge Svoysky <ssvoysky(at)gmail.com> wrote:
<IMG-0500.JPG>
