has anyone dimpled their XL?
chris_sinfield(at)yahoo.c
PostPosted: Mon Jan 16, 2006 3:46 pm    Post subject: has anyone dimpled their XL? Reply with quote
Hi All
Has anyone dimpled their XL kit?? IS it worth it and would you get any extra speed out of it due to the clean flying surfaces..
Eddie Steve has stated to dimple his tail and is about to start the wings.. It looks Good without the raised heads but he said it takes twice as long.. So the Q is ... Is it worth it just for the looks? or is there better performance...?? would it make a difference to the flying? test flight ?
I was thinking of doing the wings and tail with dimpled rivets and the fuse normally..
Chris..
Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
Larry McFarland
PostPosted: Mon Jan 16, 2006 4:22 pm    Post subject: has anyone dimpled their XL? Reply with quote
Chris,
You might just see another 2 mph airspeed, but I doubt it's worth the
work you propose to get it.
Larry McFarland
Chris sinfield wrote:
Hi All
Larry McFarland - 601HDS - Stratus
zodierocket(at)hsfx.ca
PostPosted: Mon Jan 16, 2006 4:23 pm    Post subject: has anyone dimpled their XL? Reply with quote
The effect of flat riveting over domed heads is 1/4 mph gain on speeds
below 200mph. IS the time worth it on an XL ? I doubt it, but if you
want to do it for looks then knock yourself out.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
Gig Giacona
PostPosted: Tue Jan 17, 2006 8:14 am    Post subject: Re: has anyone dimpled their XL? Reply with quote
Doesn't some of the strength come from the domed shape of the rivet?
W.R. "Gig" Giacona
601XL Under Construction
daveaustin2(at)sprint.ca
PostPosted: Tue Jan 17, 2006 8:31 am    Post subject: has anyone dimpled their XL? Reply with quote
As a test to speed production of Spitfires in WW2 they stuck split peas over
every rivet on the plane. Lost about 4 mph at 400 mph. That was too much
to give an Me 109.
Dave Austin 601HDS - 912, Spitfire Mk VIII
jhstarn(at)verizon.net
PostPosted: Tue Jan 17, 2006 9:50 am    Post subject: has anyone dimpled their XL? Reply with quote
So that's why Spitfires are green, Boy the things ya learn from the list.
8*) KABONG
d.goddard(at)ns.sympatico
PostPosted: Tue Jan 17, 2006 1:29 pm    Post subject: has anyone dimpled their XL? Reply with quote
mijniljj(at)yahoo.com
PostPosted: Tue Jan 17, 2006 2:19 pm    Post subject: has anyone dimpled their XL? Reply with quote
It doesn't have a laminar flow airfoil either so i
don't think it would make a dimes worth of difference,
may lower the landing speed because of the vortices.
jim
PostPosted: Tue Jan 17, 2006 3:24 pm    Post subject: has anyone dimpled their XL? Reply with quote
Saw a TV program the other night on Spitfires. Top speed was not the pilots
main concern. Turning and stall speed in a vertical climb was the name of
the game. They had two "Aces" on. An ME 109 & Spitfire were involved, 109
behind & both turning. 109 was gaining the advantage so the Spitfire pilot
pulled straight up in a vertical climb, the 109 followed & rolled to watch
the Spitfire. They were at about the same level looking at each other. The
first one to stall & fall off would have the other on its tail. It would
seem that the smoother the wing, the less air separation & lower stall.
Flush vs round head ? ?. The 109 stalled first, Spitfire did a modified
"hammerhead" & shot down the 109. KABONG Do No Archive
Subject: Re: RE: has anyone dimpled their XL?
jim
