n1cxo320(at)salidaco.com Guest
Posted: Sat Jul 15, 2006 4:24 pm Post subject: Lightspeed Ignition Problem |
I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free.
BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy.
On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached.
While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable.
I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions?
John
dan(at)rvproject.com Guest
Posted: Sat Jul 15, 2006 5:39 pm Post subject: Lightspeed Ignition Problem |
Check your coil connections. That is, the fast-on connectors that push onto the coil terminals. Check the wires & crimps at those connectors. Make sure there isn't any strain on 'em that has accumulated in form of poor connection or break in those wires (been there done that).
Phase your coils as per the instructions on www.lsecorp.com. Make sure both coils are firing properly.
That's about as much as I can tell ya. Let us know what works or doesn't.
)_( Dan
RV-7 N714D
http://www.rvproject.com
rvbuilder(at)sausen.net Guest
Posted: Sat Jul 15, 2006 6:19 pm Post subject: Lightspeed Ignition Problem |
If you don’t think it’s the electronics, I would look at the coils or the wires. Might be some corrosion on one of the leads or just a wire going bad.
Michael Sausen
-10 #352 Fuselage
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Fasching
Sent: Saturday, July 15, 2006 7:19 PM
To: rv-list(at)matronics.com
Subject: Lightspeed Ignition Problem
John
martin(at)gbonline.com Guest
Posted: Sat Jul 15, 2006 6:49 pm Post subject: Lightspeed Ignition Problem |
John,
I experienced similar problems several years ago. I determined that it was failure from heat soaking of the lightweight coils supplied by Klaus. He suggested I replace them with General Motors coils which I did. I have had no problems since, 1000 hours ago. Good Luck.
Dick Martin
RV8 N233M
the fast one
ronlee(at)pcisys.net Guest
Posted: Sat Jul 15, 2006 7:37 pm Post subject: Lightspeed Ignition Problem |
Just remove and reseat all the connections. I had a loss of
one side once that nothing fixed. It finally went away and my
opinion is that some corrosion impacted the connection of one
of the wires to the coils. The multiple reconnecting may have
"cleaned" the corrosion.
Ron Lee
n223rv(at)wolflakeairport Guest
Posted: Sun Jul 16, 2006 4:06 am Post subject: Lightspeed Ignition Problem |
We had the same problem. Pulled off the contacts to the coils, cleaned
them all up, and put them back together. Fixed the problem.
-Mike
chaztuna(at)adelphia.net Guest
Posted: Sun Jul 16, 2006 5:45 am Post subject: Lightspeed Ignition Problem |
Dick
What GM coils are you referring to? Late model Corvette items? V-6/V-8 DIS (distributorless Ignition System) coils? Could you supply a part number or vehicle/engine application?
Charlie Kuss
[quote]John,
Dick Martin
RV8 N233M
the fast one
lors01(at)msn.com Guest
Posted: Sun Jul 16, 2006 6:40 am Post subject: Lightspeed Ignition Problem |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Don't know what GM coils Klaus uses but, I have had similar symptoms with my system (rotary engine, but they all need spark) and it was due to heat soaking of coils. I use GM coils for the LS1 engine and the failures occurred with the truck version of the LS1. The Corvette version has always worked flawlessly.
Point being that all GM coils are not created equal. The Corvette coils are made by Nippon Denso (I love their stuff). The truck version was made by Hitachi I think.
Tracy Crook
Posted: Sun Jul 16, 2006 7:42 am Post subject: Lightspeed Ignition Problem |
Another problem I had with rough running was not obvious with a casual
inspection. One wire had broken inside the connector (lead to a coil). I
just found it by accidentally hitting the wire instead of the connector and
saw that it was broken. It is well secured now!
Since the cowl is off to fix something else I will take a picture of the
repaired
wire connection.
Ron Lee
Posted: Sun Jul 16, 2006 9:36 am Post subject: Lightspeed Ignition Problem |
Here is a link to the pic. One of the wires to the closest coil broke
just inside the insulated portion of the connector. When I rewired it
I added about three layers of heat shrink. The original method is
somewhat visible in the out of focus right side coil.
http://home.pcisys.net/~ronlee/CoilWireRepair.jpg
Ron Lee
| Quote: | Another problem I had with rough running was not obvious with a casual
repaired
wire connection.
Ron Lee
Posted: Mon Jul 17, 2006 5:11 am Post subject: Lightspeed Ignition Problem |
Charlie,
I went to an auto parts store and asked for a standard GM coil. Apparantly, this is a very common item. You will have to mount them on the firewall over a piece of non conductive material, because the contact point is on the bottom of the coil. I used brass strips to exit the coil and provide a spade connector for the input to the coil. The output of course is a sparkplug wire.
Dick Martin
Getting ready for the Air Venture race
Hopperdhh(at)aol.com Guest
Posted: Mon Jul 17, 2006 7:15 am Post subject: Lightspeed Ignition Problem |
In a message dated 7/17/2006 9:13:45 A.M. Eastern Daylight Time, martin(at)gbonline.com writes:
| Quote: | Charlie,
Dick Martin
Having worked on the design of GM's distributorless ignition systems, I can pass along a small piece of advice. Ground the laminations of the coils. I think the GM coils will have a metal strip evident under one of the mounting bolts. Be sure this gets grounded. Otherwise the laminations float to a high voltage and finally arc causing radio noise or interference to the electronics of the ignition system.
Along the same lines, if the secondary connections have even a very small gap you get what we called micro-arcing. A 1 thousandth of an inch arc, believe it or not, causes interference that can wreak havoc with the electronics of the ignition system -- that is the computer or logic driving the coils. This micro-arcing is much harder to deal with than the arc at the spark plug gap.
Dan Hopper
RV-7A
