Corvair parts
jeffreycraiggarrett(at)gm
PostPosted: Fri Aug 04, 2017 3:11 am    Post subject: Corvair parts Reply with quote
I have enough parts for sale to almost build a complete engine. A new WW engine mount
1 set of Falcon heads
10/10 nitrided crankshaft new
10 rod 10 main bearings
Case
Oil pan
Front cover
Ot-10 cam with gear
Valve covers with welded filler and vent
Baffle kit
New oil pump gear
New lifters and balls
Acorn nuts for studs
Rear accessory case
Auto meter fuel pressure gauge
Two bosh coils
New Electronic / point distributor
1 set reconditioned rods with arp rod bolts
Safety shaft
Hybrid studs
1 set plug wires
New harmonic balancer
1 set of points and condenser
Mount is for a 650 / 601 / cruiser
Asking $3000.00 for it all. I can send photos of everything.
jimandmandy(at)yahoo.com
PostPosted: Sun Aug 06, 2017 11:03 am    Post subject: Corvair parts Reply with quote
Where are the parts physically located?
From: Jeff Garrett <jeffreycraiggarrett(at)gmail.com>
Sent: Friday, August 4, 2017 4:25 AM
Subject: Corvair parts
Case
Oil pan
Front cover
Ot-10 cam with gear
Baffle kit
New oil pump gear
Rear accessory case
Two bosh coils
Safety shaft
Hybrid studs
1 set plug wires
