Peter.Sokolowski(at)t-onl Guest
Posted: Mon Jan 16, 2006 11:29 am Post subject: Battery strength |
Hello all,
as I am new on this list - this is my first try to get some needed information.
So what I have is a 24 Volt system with a 12 Volt starter on an O360 F1A6. I was told that it should not be a problem to use the 12 Volt starter with 24 Volt as the voltage will drop anyhow to about 18 Volt and the starting process itself will not take more than 20 seconds which the starter should be capable to handle.
- what is the opinion of the group on this ?
- The second issue is that I need a figure of the battery strength (Ah) which is needed to start my engine. I know that this is depending on many issues and this should not be the only consideration for the strength but there must be a general idea of whether 17 Ah should do the job easily or should one go for 24 Ah or 7 Ah.
Thanks for your recomendations
Peter (Lancair 360 MKII, 85%)
nuckollsr(at)cox.net Guest
Posted: Tue Jan 17, 2006 8:11 am Post subject: Battery strength |
At 07:25 PM 1/16/2006 +0000, you wrote:
Hello all,
information.
If it's a permanent magnet starter, it's probably not a good idea.
The earliest automotive derivatives were series wound and fairly
tolerant of short duration overloads . . . it will certainly crank
the engine faster thus reducing total abuse time of the starter.
What are your options? Take the starter off and replace it with
an newer, lighter machine or run the existing starter 'til it
croaks. Who knows, you may get considerable service life from
the existing starter and the risks are low.
| Quote: | - what is the opinion of the group on this ?
Battery size is driven more by what your no-alternator
endurance goals are. Have you conducted a load analysis
for alternator-out operations and selected a minimum endurance
time? See Chapter 17 of the 'Connection.
Fred Stucklen
Joined: 10 Jan 2006 Posts: 10 Location: East Windsor, CT
Posted: Wed Jan 18, 2006 8:10 am Post subject: Battery strength |
Another important issue might also be the speed at which the starter turns
the engine. Most impulse mags will not operate properly if the engine spins
too
fast. This was a typical issue with the C-152 after they went to a 24 Volt
system.
Fred Stucklen
RV-6A N926RV
nuckollsr(at)cox.net <mailto:nuckollsr(at)cox.net> >
<mailto:Peter.Sokolowski(at)t-online.de>
>Hello all,
>information.
F1A6.
with
starting
should
(Ah)
many
but
easily or
Posted: Wed Jan 18, 2006 9:09 am Post subject: Battery strength |
At 11:01 AM 1/18/2006 -0500, you wrote:
<Fred.Stucklen(at)utcfuelcells.com>
too
system.
Hmmm . . . good point. Peter, did you catch this?
| Quote: | Fred Stucklen
RV-6A N926RV
>Hello all,
>information.
F1A6.
with
starting
should
(Ah)
many
but
easily or
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it devine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
http://www.aeroelectric.com
