500B hydraulic pump parts
aquadiver99(at)yahoo.com
PostPosted: Fri Jan 13, 2006 10:08 am    Post subject: 500B hydraulic pump parts Reply with quote
Dear members, does anyone have any info on the below
topic?
Thank you in advance...
Good morning Mr. Tower,
You had offered you help earlier in the Commander
search for things and now I surely need it. I am in
need of an oil seal for one of the main hydraulic
pumps in my 1964 500B. My serial number is in the
upper bracket [1300-] and the pump was manufactured by
Eastern Industries, Hamden, CT. Model number of the
pump is 105HBG-211B, part 4790222-501.
The seal is on the input shaft and is in itself unique
because of it's unusual depth of .690 on the outer
case housing a double seal. I have found two smaller
seals to "stack" in the originals place but would
prefer OEM config. These two seals were obtained from
Motion Industries with no other options.
I sure hope you or one of the other members of the
chat group can help Mr. Tower, I have exhausted all of
my options.
Best Regards,
Donnie Rose
Donnie Rose
205/492-8444
Donnie Rose
205/492-8444
mashley2(at)kc.rr.com
PostPosted: Mon Jan 16, 2006 5:48 am    Post subject: 500B hydraulic pump parts Reply with quote
Aircraft accessories of oklahoma are the experts for the hydrualic pumps.
800-255-9924
Good Luck,
Myron Ashley
PostPosted: Tue Jan 17, 2006 7:17 am    Post subject: 500B hydraulic pump parts Reply with quote
Thank you Myron.
Donnie
800-255-9924
Good Luck,
Myron Ashley
