mercecedes116(at)gmail.co Guest
Posted: Mon Jan 16, 2017 6:33 am Post subject: Floats, cage no. |
Hello all. I have found a set of lightning floats and am looking for the history of them. I think they are made in Fla. They are fiberglass outside, weight is 35lbs each. I recently bought a second Kolb, a firefly. I can't find any number on the top tube end. Is there one? Thanks for any info.
Posted: Mon Jan 16, 2017 6:43 am Post subject: Floats, cage no. |
Can you post a couple of photos of the Firefly?
Bill Sullivan
Windsor Locks, Ct.
On Mon, 1/16/17, Del Vinal <mercecedes116(at)gmail.com> wrote:
Subject: Floats, cage no.
Date: Monday, January 16, 2017, 9:33 AM
Hello all. I
info.
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Mon Jan 16, 2017 2:25 pm Post subject: Re: Floats, cage no. |
Herb G gave me a damaged cage from an early Firefly, it has a serial number on an aluminum plate riveted to the side of the top tube just behind the front spar carry through.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
lcottrell
Joined: 29 May 2006 Posts: 1490 Location: Jordan Valley, Or
Posted: Mon Jan 16, 2017 2:46 pm Post subject: Floats, cage no. |
I think that you are going to find that the only serial numbers on any of the Kolb cages will be the one that you put there. For years I used FSII thinking that the number punched into the back of the upper cage main support was a serial number. I finally realized that it merely told them which plane it was intended for. :-/
Larry
On Mon, Jan 16, 2017 at 3:25 PM, Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
Richard Pike
Kingsport, TN 3TN0
There are only two kinds of people in the world. Those who say to God; "Thy will be done."
And those to whom God says ; "OK then; have it your way."
http://forums.matronics.com/viewtopic.php?p=465144#465144
The older I get, the less tolerant I am of those who are intolerant of others.
