algate(at)attglobal.net Guest
Posted: Tue Jul 11, 2006 9:24 am Post subject: Navman |
Somebody mentioned previously a price and contact for the Navman fuel flow
meter. I have a friend looking for one and would appreciate it if I could
get the contact details.
Best regards
Gary Algate
dave(at)cfisher.com Guest
Posted: Tue Jul 11, 2006 9:38 am Post subject: Navman |
Gary,
I got mine here for 111 $ shipped to Canada overnight , I think it was 130$
total and works fine.
I just flew 7.5 hour x country in 582 on Floats and fuel flow and usage
seemed to be right on the numbers.
http://www.boatersland.com/navf2100.html
Dave
msm_9949(at)yahoo.com Guest
Posted: Tue Jul 11, 2006 10:31 am Post subject: Navman |
Dave -
Where in your fuel system did you install the transducer for your Navman?
Dave <dave(at)cfisher.com> wrote:
| Quote: | --> Kitfox-List message posted by: "Dave"
Gary,
Marco Menezes
Model 2 582 N99KX
Yahoo! Music Unlimited - Access over 1 million songs. [url=http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.yahoo.com/unlimited/ ]Try it free.[/url]
Posted: Tue Jul 11, 2006 10:41 am Post subject: Navman |
Hi Marco.
It is right below the fuel pump that is mounted to the firewall after the gascolator. Only thing I did not like is that the transducer is 3/8" and my fuel line is 1/4" I used angle adapters and it seems to work ok. I would guess over 100 hours on it now.
Dave
Posted: Tue Jul 11, 2006 11:04 am Post subject: Navman |
Likewise I have the Mizer already installed in my Kitfox with over 300 hrs. The Mizer is the Navman with a new Decal and an aviation rating and a new price : +$300.00
The transducer is carbon reinforced plastic and I have it fitted between the main filter and the inlet of the fuel pump. Cliff mentioned that he felt the plastic transducer might be a problem but I have the same transducer and it is certified for aviation use so I think in this instance it is fine.
After 4500 ltrs of fuel it reads accuracy to within 1 ltr. Pretty amazing.
To Dave – Thanks for the info I’ll contact them today
Gary Algate
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dave
Sent: Tuesday, July 11, 2006 2:41 PM
Subject: Re: Navman
Hi Marco.
Dave
Posted: Tue Jul 11, 2006 11:30 am Post subject: Navman |
Gary it sounds like your transducer is quite the same as my Navman.
Dave
shoeless(at)barefootpilot Guest
Posted: Tue Jul 11, 2006 11:36 am Post subject: Navman |
Gary,
I didn't know they had one for avaition use. Mine is the marine unit and not
really suitable for aviation. I would like to see this aviation unit, I
couldn't find it on their web site at www.navman.com.
Cliff
price : +$300.00
To Dave - Thanks for the info I'll contact them today
Gary Algate
_____
Hi Marco.
Dave
morid(at)northland.lib.mi Guest
Posted: Tue Jul 11, 2006 12:47 pm Post subject: Navman |
Don't forget about Floscan. It's also an excellent unit as I can attest after 325 hours. Very accurate. Available in marine catalogs line Consumer Marine, West Marine, etc.
Deke
pwmac(at)sisna.com Guest
Posted: Tue Jul 11, 2006 2:20 pm Post subject: Navman |
Hey Cliff,
I searched and searched for Fuel Mizer then found out that Navman
took them over same country - Australia. When the list discovered the
Fuel Mizer, way back in time, the guys who bought them said the
aviation on had threaded fittings and the boat one had push-on hose
fittings. Now the aviation one is over USD300 and the boat one is a
little over USD100. The transducer and the head were apparently the
same. It has a small turbine just like the Flowscan. IMO, push-on
connection works just fine, just like the pushon connection on the
Rotax fuel pump. Both were 3/8" fittings. Installation for those who
have not got one should be in a vertical line downstream of your fuel
filter. Per the install manual.
With regard to "not suitable for aviation". I strongly disagree. The
things are made for marine use and they use the same gasoline laced
with bad chemicals that we use in our cars. I think the Coast guard
would ban them if they ever failed and caused a fuel leak. That
feature alone makes it suitable for my use.
Regards, Paul
PS, I guess you use Mil 6000 fuel hose because the stuff is approved
for aviation. Good luck. PW
At 01:34 PM 7/11/2006, you wrote:
<shoeless(at)barefootpilot.com>
Gary,
Cliff
price : +$300.00
Gary Algate
_____
Hi Marco.
Dave
Posted: Tue Jul 11, 2006 3:39 pm Post subject: Navman |
Paul,
I would be happy if I had the screw-on fittings (metal)
What I have is the marine plastic push on. The unit works well enough and
will certainly stand up to any fuel that I throw at it. The issue is the
flimsy plastic hose barbs. It for this reason and this reason only that I
made the statement about not being suitable for aviation and I STRONGLY
stand by that statement.
This is experimental aviation so you can use whatever you want. I clearly
gave my reason for my statement in a previous message, but no one has
bothered to address that issue. Instead I get sarcasm about Mil 6000. If you
paid the least bit attention you would know that I was one who suffered mil
6000 destruction when using mogas on our first kitfox and I have been a
strong opponent of that crap for mogas use ever since. Despite the
experience of many on the list there are still those with their head in the
sand about mil 6000. Just because it hasn't happened to them ...it's not a
problem. I have first hand experience with the marine sender with the
plastic hose barb fittings, do you?
I have lots of "experimental" stuff on my plane, but each item is evaluated
for it's suitability for the job and for the environment in which it has to
perform. Despite the insinuation, I am not one of those that only uses
official "aviation" approved parts. But I am one that tries to spot problems
areas BEFORE they become a problem.
The reality is that the marine fuel sender "might" just last a long time in
an airplane, or it might not. In my view the one with the plastic hose barbs
is suspect and there are better options available.
I like my Navman unit, but I want to replace the sender. The fuel mizer unit
might be just the ticket, or I might try a flowscan sender for under $200.
The fuel mizer with the threaded fittings sound like a great unit, but I
still would recommend to those that haven't installed one yet to NOT use the
one with plastic hose barb fittings. It's my opinion and it's likely worth
what you paid for it.
I'm finished venting now, lets go have a beer together...
Best regards,
Cliff
PS, I've had my share of issues with our kitfoxes over the years and I
always try to share with the list the ones that I think are important
(meaning someone could get hurt) But I have learned that most people will
pay no heed to it until it happens to them. I have no delusion about
changing anyone's mind that already has a marine sender in their plane. I
make these comments for the builder that hasn't installed one yet.
Hey Cliff,
Regards, Paul
Gary,
not
Cliff
price : +$300.00
the
and
Gary Algate
_____
Hi Marco.
Dave
Posted: Wed Jul 12, 2006 8:06 am Post subject: Navman |
I think I speak for everyone on the list in saying we sincerely appreciate your insights and experience Cliff. You clearly have a strong opinion on this. As a builder who has not yet installed a marine transducer into his fuel system (but is leaning in that direction), I'm very curious as to exactly what your experience has been with the barbed hose fittings on the NavMan transducer. Have you had one fail or do you know of one failing either in marine or aviation applications? Just trying to get the facts.
Thanks.
Clifford Begnaud <shoeless(at)barefootpilot.com> wrote:
[quote]--> Kitfox-List message posted by: "Clifford Begnaud"
Paul,
Best regards,
Cliff
Hey Cliff,
Regards, Paul
Gary,
not
Cliff
price : +$300.00
the
and
Gary Algate
_____
Hi Marco.
Dave
Posted: Wed Jul 12, 2006 9:13 am Post subject: Navman |
Marco
It has not failed... yet. I don't know of any that have failed, but then I
don't know who else has it installed. At one point my mil 6000 fuel hose had
not failed, at one point my aluminum tailwheel spring had not failed, at one
point my second aluminum tailwheel spring had not failed, at one point my
two- leaf steel tw spring had not failed, at one point the fuel sight tube
fittings had not failed, at one point my rudder pedals had not failed, at
one point ....well do I really need to go on?
The plastic barbs might NEVER fail. It might outlive the airplane. This is
just about balancing the choices about what you put in your plane. The point
is that it is a potential failure point and if it does fail in flight, what
are the consequences? I'm just balancing the chances of failure with the
consequences of failure. If the only other choice cost $1000 more, that
would certainly change the formula. But the cost difference between the
plastic hose barbs and something better is not that great.
The formula for balancing risk vs reward will be different for each of us.
I'm just sharing the way that I look at things. I have spent my entire life
doing very risky things, aviation being one of the safer ones. I even make
my living balancing risk vs reward every day by trading the futures markets.
I've seen the consequences of poorly balanced risk vs reward far too many
times....
Best regards,
Cliff
Thanks.
