		Edwardoc
  Joined: 20 Aug 2009 Posts: 8 Location: Kersey, CO 80634
				 Posted: Mon Jul 11, 2016 6:18 pm    Post subject: Rear Crankshaft Expansion plug removal and install |
				Anyone have experience or advise on removing a leaking rear expansion plug in a hollow crank.  It is loose in the crank and needs to be removed and insert a new one.  Any advice or experiences doing this procedure would be appreciated.
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gary.A.Sobek
				 Posted: Mon Jul 11, 2016 7:18 pm    Post subject: Rear Crankshaft Expansion plug removal and install |
				Is it possible that the one that is installed only needs seated?
 I have a friend that had his 360 overhauled. When it came back, it flew
 fine for about 100-hours then the prop would go to high RPM.  The cause
 was found to be the rear plug was not seated properly.  A tool was
 fabricated by one of his machinist friends and the plug was seated.
 That was over 1,000 flying hours ago without any additional prop going
 to high RPM without the blue knob being pushed forward.
 On 07-11-2016 10:18 PM, Edwardoc wrote:
  http://forums.matronics.com/viewtopic.php?p=458092#458092
		ceengland7(at)gmail.com Guest
				 Posted: Mon Jul 11, 2016 7:28 pm    Post subject: Rear Crankshaft Expansion plug removal and install |
				On 7/11/2016 9:18 PM, Edwardoc wrote:
 This might be what you're looking for.
 http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201435%20(04-25-1986)/Conversion%20from%20Constant%20Speed%20to%20Fixed%20Pitch%20Propeller%20and%20Vice%20Versa;%20....pdf
 Charlie
