Max. Oil Consumption
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
klwerner(at)comcast.net
PostPosted: Sat Jul 01, 2006 4:17 pm    Post subject: Max. Oil Consumption Reply with quote
Fellow Lister,
Does anyone know how excessive an engines oil consumption can become, before one should take it apart for an overhaul?
What does Lycoming recommend in regard to max allowed oil consumption?
Thanks, Konrad
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
archie97(at)earthlink.net
PostPosted: Sat Jul 01, 2006 5:20 pm    Post subject: Max. Oil Consumption Reply with quote
Lycoming has a formula, which I have not memorized, but can post it to-morrow.
It varies with each engine, but the amount allowable is so liberal, it is frightening.
Archie
PostPosted: Sat Jul 01, 2006 6:42 pm    Post subject: Max. Oil Consumption Reply with quote
Just found a copy here in my office.
.006 X BHP X 4 / 7.4 = qt. per hr.
Hopperdhh(at)aol.com
PostPosted: Sun Jul 02, 2006 3:32 pm    Post subject: Max. Oil Consumption Reply with quote
Archie,
Just curious -- why wouldn't it just be simplified to:
.00324xBHP=consumption in qt. per hr.
Is 4 the number of cylinders?  What do the terms stand for?
Dan Hopper
RV-7A
In a message dated 7/1/2006 10:43:46 P.M. Eastern Daylight Time, archie97(at)earthlink.net writes:
[quote] Just found a copy here in my office.
PostPosted: Sun Jul 02, 2006 4:15 pm    Post subject: Max. Oil Consumption Reply with quote
Did not take the time to analyze the formula. Just as given by Lycoming.
To the best of my knowledge, this applies to all their piston engines,
therefore the 4 would not fit.
As far as I am concerned, one quart between oil changes is enough, but
have been there before, and have told people how it is done.
(albeit against manufacturer and FAA edicts)
Nuff said.
Archie
jrccea(at)bellsouth.net
PostPosted: Mon Jul 03, 2006 4:55 am    Post subject: Max. Oil Consumption Reply with quote
One would expect the number of cylinders to factor into the oil consumption.  I'd be surprised if it doesn't.
JimC
PostPosted: Mon Jul 03, 2006 5:00 am    Post subject: Max. Oil Consumption Reply with quote
The equation is given in Lycoming Service Instruction 1427B.
Here's a URL.
http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/maintenance/reciprocatingEngine.html
glcasey(at)adelphia.net
PostPosted: Mon Jul 03, 2006 5:13 am    Post subject: Max. Oil Consumption Reply with quote
I once saw in similar equation published by Continental.  Yes, indeed, they could have made it much simpler, but I'm pretty sure all the extra numbers just convert pounds to quarts.  4 quarts per gallon and the density is about 7.4 pounds per gallon.  And everyone (including me) must have stopped at OSH and asked them the same question about oil level.  I was told that the top quart or two were there mostly for long ferry flights where any increased oil consumption during the flight would give maximum capability of arriving.  Don't know, but in a flight behind my IO-360 I burned 2 qts. in an hour's flight.  If the flight were much longer I would have needed all 8.  The reason it seems to blow out the first quart or two is (supposedly) that during initial climbout the oil level is higher at the back and gets into the gearcase, where it is slung up to the top of the engine.   And as some have mentioned, a sudden change in consumption is almost more important than the consumption rate itself since in aviation it seems that any unexpected change is a bad change.
I'm trying to figure out my newly-overhauled high-compression IO-540, which started off not burning too much oil (good sign I thought).  But now with about 15 hours on the engine I'm getting what seems to be ever increasing blowby.  Now the oil drops on the gear leg are real drops, not just oil dark spots.  Broken ring?
PostPosted: Mon Jul 03, 2006 5:58 am    Post subject: Max. Oil Consumption Reply with quote
Not likely, Gary, but possible.
Usually a blowby problem. With antiquated iron ring designs, and very liberal end gaps,
this is to be expected. Keep in mind, that as the rings wear in, the gaps also increase,
accentuating the blowby.  The "perfect" engine has none.
We have no break in on race engines as such. No time for that when racing so we use
the latest technologies in piston rings.
A leakdown of more than 2-3% indicates hp loss and mandates investigation.
Rhonda(at)bpaengines.com
PostPosted: Mon Jul 03, 2006 6:08 am    Post subject: Max. Oil Consumption Reply with quote
Gary:
Blowby as described by Archie below, typically occurs when the cylinders become glazed.  This is often caused by allowing the engine to get too hot (usually a long run up on the ground.)  If this is the case, you should be able to have the cylinders cleaned up by your engine shop or a good cylinder o’h shop.
[i]Rhonda[/i]
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Archie
Sent: Monday, July 03, 2006 8:54 AM
To: engines-list(at)matronics.com
Subject: Re: Max. Oil Consumption
jtrampota(at)eci2fly.com
PostPosted: Mon Jul 03, 2006 6:19 am    Post subject: Max. Oil Consumption Reply with quote
One of the visual signs that you have blowby is the rapid darkening of the oil color after you have changed the oil...  Blowby/glazing simply lets the combustion past the rings/cylinder born directly into the case ,,, hence black/discolored oil..
JT
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Rhonda Bewley
Sent: Monday, July 03, 2006 9:06 AM
Subject: RE: Max. Oil Consumption
Gary:
[i]Rhonda[/i]
s_korney(at)hotmail.com
PostPosted: Mon Jul 03, 2006 3:30 pm    Post subject: Max. Oil Consumption Reply with quote
How many hours after an oil change would you say the oil would start to turn
dark on a good engine...
Best... Steve
----Original Message Follows----
Reply-To: engines-list(at)matronics.com
JT
Bewley
Gary:
good cylinder o'h shop.
Rhonda
liberal end gaps,
gaps also increase,
racing so we use
investigation.
PostPosted: Wed Jul 05, 2006 4:37 am    Post subject: Max. Oil Consumption Reply with quote
Depending on the severity anywhere within the 1st 5 hours
JT
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
