Pable Mackenzie Guest
Posted: Thu Dec 04, 2014 9:45 pm Post subject: Aircraft Engine Data Management System |
Hi Dear Friends.
Let's me allow to share and gain knowledge from you if you having same interest related to Aircraft Instrument.
Aircraft cockpits tend to have numerous dials and indicators that monitor; some cases diagnose and display aircraft engine data. First off, it is nearly impossible to see all the monitors at the same time and secondly, a problem might not be apparent unless you can take data from two or more instruments and analyze it.
Aircraft engine data management system is required to collect and log data from various components, systems and sub-systems. It gathers and logs actions, performance and status of various critical components within the aircraft.
Modern aircraft engine data management system can even draw certain conclusions based on algorithms programmed into the collection system. The aim of aircraft engine data management system is to maximise reliability and availability of useful data. Of course, the aircraft engine data management system will not stop an aircraft component from malfunctioning, but it will provide vital data that will help diagnose problems that resulted in the failure of that component. It could even be used to predict a catastrophic failure weeks before it occurs.
Aircraft engine data management system gives you the freedom of knowing how well the aircraft engine is performing. Modern aircraft engine data management system can significantly reduced your maintenance costs by flagging what could well be costly technical problems in the early stages of development.
This early detection always saves costly repairs. Aircraft engine data management systems reveal operational profiles of technical performance from individual components to the entire aircraft engine. This in turn takes the guesswork out from maintenance requirements and would also help engineers develop a more thorough and cost-effective maintenance schedules.
If you knew more about this or want know about other related parts, please feel free to write me.
Best Regards
Pable Mackenzie
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
