Do away with your fuel related anxiety with our FS-450 Fuel
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Pable Mackenzie
PostPosted: Wed Nov 26, 2014 11:31 pm    Post subject: Do away with your fuel related anxiety with our FS-450 Fuel Reply with quote
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts.
Better the mileage, longer the distance you can fly and consequently, greater the pleasure. Ever since the Wright brothers first flew their plane, figuring out maximum range for your aircraft has always been guesswork. Between then and now science and technology has made such strides that one would have thought that designing an instrument that helps calculate your fuel consumption and consequently the range, would have been a breeze.
It is not just calculating the range before the actual flight that is the problem; during flight too there can be lots of unexpected factors that result in higher fuel consumption. So what is your new range? Looking at the fuel gauges with their bouncing needles that bob in synch with the floats in the two wing tanks is not exactly helpful.
Well, guess what, the long wait for an instrument that provides you with precise fuel consumption data is over. J.P. Instruments of Huntington Beach, California, USA, has designed just such an instrument. It is called the FS-450 Fuel Totalizer.
Pilots who have installed the instrument swear that the Fuel Scan 450 fuel totalizer relegates fuel-situation anxieties to aircraft history. It constantly displays your aircraft’s current fuel-consumption on the top of two bright LED displays and that’s not all it does.
The FS-450 fuel totalizer also displays total fuel consumption since engine start, how much is left in the tanks and how long it would last at current setting. As if that were not enough, it also displays the quantum of fuel needed to reach your next waypoint and how much fuel would remain at the point and also, the fuel efficiency of your aircraft (GPS connection required).
If you knew more about this or want know about other related parts, please feel free to write me.
Best Regards
Pable Mackenzie
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
 Filesize:  47.66 KB
 Viewed:  4553 Time(s)
 Filesize:  30.6 KB
 Filesize:  30.43 KB
 Filesize:  47.66 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
