7-V-7-4 Inboard Trailing Edge
pdelano(at)telus.net
PostPosted: Mon Oct 27, 2014 3:43 pm    Post subject: 7-V-7-4 Inboard Trailing Edge Reply with quote
Hi All,
I am puzzled. As far as I can determine for the right wing (which is hung on the wall) I cut out the inboard trailing edge as shown on the 10/2002 drawings, specifically made the the fore to aft cut 22 mm deep to allow for clearance of 7V4-4 as shown on the lower left corner of 7-V-7. However on the left wing the trailing edge at 7V4-4 does not seem to want to come flush with the trailing edge of the top rear skin. It seems I would need to make this cut about 27 mm deep. Was there an update to the drawings for this dimension that I just don’t seem to be able to find now. I am trying not to jump to a solution that is not required.
Thank you in advance for any help with this query.
Perry
JohnDRead(at)aol.com
PostPosted: Tue Oct 28, 2014 3:47 pm    Post subject: 7-V-7-4 Inboard Trailing Edge Reply with quote
Call the factory.
John Read
Home: 303.648.3261
Mobile: 719.494.4567
In a message dated 10/27/2014 5:43:48 P.M. Mountain Daylight Time, pdelano(at)telus.net writes:
Hi All,
Perry
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
PostPosted: Wed Oct 29, 2014 6:08 am    Post subject: 7-V-7-4 Inboard Trailing Edge Reply with quote
Hi John,
As always; good advice.
Perry
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Tuesday, October 28, 2014 4:47 PM
Subject: Re: 7-V-7-4 Inboard Trailing Edge
Call the factory.
John Read
Home: 303.648.3261
In a message dated 10/27/2014 5:43:48 P.M. Mountain Daylight Time, pdelano(at)telus.net (pdelano(at)telus.net) writes:
Hi All,
Perry
====================================List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List====================================ms.matronics.com/">http://forums.matronics.com====================================tp://www.matronics.com/contribution">http://www.matronics.com/contribution====================================
Checked by AVG - www.avg.com
Version: 2014.0.4765 / 10/28/14
