fly4grins(at)gmail.com Guest
Posted: Sat Oct 25, 2014 5:04 am Post subject: was RV- 14, now electrical redundancy |
I wrestled with the same issues, and although I've not yet flown my night / ifr capable RV yet, I like what I've come up with. The short version is that I've a primary efis w/ engine instruments and a backup efis six pack. Given that cranking and avoiding brown out pretty well required two batteries, I ultimately adopted Bob's two identical battery, swap one out per year concept. The starter, main alternator, main bus (including the switched stby efis), and main battery comprise one branch of my system. The essential  battery (Sorry folks;  I'm not interested in any semantic arguments...  call it a kumquat if you like!) carries the essential bus, which powers the primary efis un-switched and is supported by an SD-8 on the vacuum pad. The two batteries are tied together with a Schotkey diode, and the SD-8 regulator is set between battery and main alternator voltage. Â
Operation is dirt simple. Starting with the main alt off tests the stby. In flight, the main alt carries the whole electrical system. Should the main alt fail, the main bus is carried by the main battery and the SD-8 picks up the essential bus with precisely zero switch flipping by the pilot. The efis will annunciate the drop in main bus voltage. Load shedding at one's leisure will prolong the life of the main bus, but the SD-8 will ensure all the most important goodies have power for probably two hours after the prop stops windmilling, even with battery contactors on line.  Â
I use fuses, with the only breakers on power sources. Failure of ANY one component can't hurt me. YMMV, but I like it, a lot.
Kellym
Posted: Sat Oct 25, 2014 6:24 am Post subject: was RV- 14, now electrical redundancy |
This discussion, as good as it is, has focused on hardware installed and
its capabilities, not mission "need".
Need varies from a military requirement to complete the mission
regardless of circumstances to if something fails I will land at nearest
suitable airport and deal with it. Night IFR by itself only has certain
minimum requirements, and if you "assume" that your missions will keep
you within XX minutes of a suitable airport, your needs are different
than if you assume you will need to fly to destination and thus need
electron capacity equal to the aircraft fuel range. Having electron
capacity greater than fuel range just adds unnecessary wt.
Then there is the consideration of how much effort the backups need to
allow pilot with minimum effort to safely reach his pre-determined goal.
I like the system described below, IF you assume your mission is over
hostile terrain, at night in IFR and need to go a considerable distance
to a suitable landing spot after a failure. Most of us don't really have
that mission requirement, but may want the capability.
Personally, having managed to escape a night time partial panel episode
in a non-radar mountainous region will no longer consider combining
night, IFR and mountains on the same flight in a single engine normally
aspirated aircraft. My preference would be to limit risk to one of those
challenges, but will consider a flight that combines two of them.
However, I really don't want mountains at night in anything with only
one engine and no turbo regardless of VFR or IFR. I already have enough
experience there to not want to do it again.
That is why I consider suitable IFR backup to be enough electrons to
function for 1 hour, maybe 1+30 to be adequate, and easily achievable
with batteries only backup rather than a second alternator. Each builder
will have to assess their mission goals and risk tolerance to decide how
much redundancy they need and how much they want. How much complexity
that does or does not add is a minor factor in the equation. I believe
Bob has always pushed us to most carefully evaluate what our goals and
mission needs were to decide on what architecture is appropriate.
On 10/25/2014 6:03 AM, GLEN MATEJCEK wrote:
Peter and Jeff-
KCHD |
Posted: Sat Oct 25, 2014 7:49 am Post subject: was RV- 14, now electrical redundancy |
achievable with batteries only backup rather than a second alternator.
But why limit your horizon to 90 minutes if there's
simple, light, low cost of ownership combination of
hardware and planing that keeps the panel lit until
the engine runs out of fuel?
This is a mode of thinking not generally offered to
C-172 owners. I had a conversation with a company
pilot at Beech who had just delivered a new A-36
to a proud customer. He was extolling the virtues
of all the electro-whizzies on the panel to the
customer.
Later, I asked, "Did you check the guy out in flying
this airplane in the J-3 mode"?
"Say what? Why would I do that? He just paid a half
million for an airplane with air conditioning and the
kitchen sink . . . why would I even suggest that
he might want to acquire such skills about?"
Why indeed. The point is, I respectfully suggest that
there is no reason any OBAM aviation pilot should
experience an electrical 'emergency'. No single failure
should be cause to seek the nearest airport in boonies
because risks for continued flight to airport of
intended destination have driven up your pucker-factor.
| Quote: | Each builder will have to assess their mission goals and risk
tolerance . . .
Right ON! Let's not 'tolerate' risk, let's drive
it so close to zero that throwing a prop-bolt becomes
the more likely event to ruin your day.
ralphmariafinch(at)gmail. Guest
Posted: Sat Oct 25, 2014 8:56 am Post subject: was RV- 14, now electrical redundancy |
On Sat, Oct 25, 2014 at 7:22 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
This discussion, as good as it is, has focused on hardware installed and its capabilities, not mission "need".
Not true. I speculated on the OP's mission: IFR as stated, possibly at night, probably single-pilot, certainly single engine.
| Quote: | | Need varies from a military requirement to complete the mission regardless of circumstances to if something fails I will land at nearest suitable airport and deal with it. Night IFR by itself only has certain minimum requirements, and if you "assume" that your missions will keep you within XX minutes of a suitable airport, |
An optimistic assumption...dangerous to make. Better to make pessimistic assumptions.
| Quote: | your needs are different than if you assume you will need to fly to destination and thus need electron capacity equal to the aircraft fuel range. Having electron capacity greater than fuel range just adds unnecessary wt.
No. Aircraft batteries add more weight than standby alternators and provide much less endurance. At any rate, a bit of extra weight for an RV-14 is hardly the critical factor.
| Quote: | Then there is the consideration of how much effort the backups need to allow pilot with minimum effort to safely reach his pre-determined goal.
I like the system described below, IF you assume your mission is over hostile terrain, at night in IFR and need to go a considerable distance to a suitable landing spot after a failure. Most of us don't really have that mission requirement, but may want the capability.
Most of the inter-mountain West (USA) would be considered hostile terrain as is the Appalachian Range; we don't know where the OP lives, but at some point he might cross them. Airports in the mountains are not close together. And what if a nearby airport is under minimums and he needs to travel a distance to reach an acceptable airport? He may not plan on night IFR, but could easily find himself with a choice: late departure, arriving at destination at night, OR stay overnight in Podunk Airport and leave in the morning.
So plan for a system with at least, say, a 2- or 3-hour e-buss capacity. But as Bob points out, it's easy--not more effort--to add indefinite endurance, so why not do it?
I don't understand the notion that a 2nd alternator is greatly increased complexity and effort, therefore all backup must be battery. Once you are trapped in that thinking, poor trade-offs result.
Posted: Sat Oct 25, 2014 9:40 am Post subject: was RV- 14, now electrical redundancy |
| Quote: | | I don't understand the notion that a 2nd alternator is greatly increased complexity and effort, therefore all backup must be battery. Once you are trapped in that thinking, poor trade-offs result. |
Precisely. "greatly increased" is non-quantified. To quote from
one of my heros . . .
"When you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge of it is of a meager and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely, in your thoughts, advanced it to the stage of science."
Sir William Thompson, Lord Kelvin (1824-1907)
and one other . . .
"A number cited without knowing its degree of uncertainty is meaningless"
Walter Lewin (PhD Physics and professor at MIT)
These two gentlemen laid foundation for my suggestion to our
newest member to the List who was starting to plan his
electrical system, buy parts and start drilling holes.
I suggested that he first make a list of every electrical
load in the airplane and assign its duties in the conduct
of various phases of flight. Those numbers combined with
an assessment of criticality to comfortable continuation
of flight to airport of intended destination is where
one might begin to size the task and make measured
decisions of known significance.
Task I: Measure and tabulate it . . .
Bob . . . [quote][b]
jluckey(at)pacbell.net Guest
Posted: Sat Oct 25, 2014 10:42 am Post subject: was RV- 14, now electrical redundancy |
".. I don't understand the notion that a 2nd alternator is greatly increased complexity and effort, therefore all backup must be battery. Once you are trapped in that thinking, poor trade-offs result."
Ralph, it is unclear from the context; are you promoting a single battery, dual alternator system? I don't see any problem with that, given a particular set of design criteria.
If one of your goals is to maximize endurance after an alternator failure, then the second alternator makes sense. However, a system with a single battery does not solve the brown-out at start-up problem.
So it comes down to what's important to you. There is no right or wrong answer - there can be different designs based upon different sets of constraints & criteria that result in different, but equally legitimate, designs.
-Jeff
On Saturday, October 25, 2014 10:49 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
| Quote: | | I don't understand the notion that a 2nd alternator is greatly increased complexity and effort, therefore all backup must be battery. Once you are trapped in that thinking, poor trade-offs result. | Precisely. "greatly increased" is non-quantified. To quote from one of my heros . . . "When you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge of it is of a meager and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely, in your thoughts, advanced it to the stage of science." Sir William Thompson, Lord Kelvin (1824-1907) and one other . . . "A number cited without knowing its degree of uncertainty is meaningless" Walter Lewin (PhD Physics and professor at MIT) These two gentlemen laid foundation for my suggestion to our newest member to the List who was starting to plan his electrical system, buy parts and start drilling holes. I suggested that he first make a list of every electrical load in the airplane and assign its duties in the conduct of various phases of flight. Those numbers combined with an assessment of criticality to comfortable continuation of flight to airport of intended destination is where one might begin to size the task and make measured decisions of known significance. Task I: Measure and tabulate it . . . Bob . . .
jmjones2000(at)mindspring Guest
Posted: Sat Oct 25, 2014 1:49 pm Post subject: was RV- 14, now electrical redundancy |
Glen,
What Schotkey diode part number are you using?
Thanks!
Justin
On Oct 25, 2014, at 07:03, GLEN MATEJCEK <fly4grins(at)gmail.com (fly4grins(at)gmail.com)> wrote:
lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
//forums.matronics.com
Posted: Sat Oct 25, 2014 3:37 pm Post subject: was RV- 14, now electrical redundancy |
On Sat, Oct 25, 2014 at 11:41 AM, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
| Quote: | ".. I don't understand the notion that a 2nd alternator is greatly increased complexity and effort, therefore all backup must be battery. Once you are trapped in that thinking, poor trade-offs result."
Not necessarily, two aircraft batteries may be preferable for the OP's mission and tolerance of risk. I AM arguing against the apparent insistence by at least one here that a 2nd alternator adds such complexity it should not be considered.
Don't know what that is precisely...if it's important, then put in a 2nd battery. Sounds like someone is turning on all the avionics, then starting the engine...if so, couldn't the engine be started, then turn on the glass panels?
| Quote: | So it comes down to what's important to you. There is no right or wrong answer
There are multiple solutions or answers to the OP's question, with different levels of satisfying his requirements. But forgoing a 2nd alternator because it's "complicated" is not true and is unhelpful.
