Chillyz
Posted: Mon Apr 28, 2014 12:43 pm Post subject: Parking Brakes |
Hello Group,
Has anyone installed parking brakes on their aircraft? I was wondering what some of you are using? How to install and how difficult it was/is. I think Matco has a little hand-operated brake kit for sale at Spruce. It's a valve body with 2-inlet and 2-outlet fitting connections and an actuator arm that applies up to 1200 psi to hold the brakes. Not too familiar with the setup. Any help would be greatful. Thanks. Summer is almost here!!!
esalehto(at)yahoo.com Guest
Posted: Mon Apr 28, 2014 2:55 pm Post subject: Parking Brakes |
Hi,
I installed parking brakes when I build the plane. So simply to install that it can't go wrong!
Esa
Pulsar XP
Rotax 912 UL
Sent: ‎4/‎28/‎2014 15:49
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Parking Brakes
--> Pulsar-List message posted by: "Chillyz" <mypulsar3(at)gmail.com>
Hello Group,
http://forums.matronics.com/viewtopic.php?p=4225========================_========
pulsarbob(at)comcast.net Guest
Posted: Mon Apr 28, 2014 4:29 pm Post subject: Parking Brakes |
Chillz
I installed the Matco brakes with the parking brake. The biggest problem is installing the control where
you can reach it when you need it.
Pulsarbob, Bob Taylor
Sent: Monday, April 28, 2014 4:43:14 PM
Hello Group,
http://forums.matronics.com/viewtopic.php?p=422522#422522
bernard.wilder2(at)gmail. Guest
Posted: Mon Apr 28, 2014 5:26 pm Post subject: Parking Brakes |
Have one installed.
Â
Never use it.
Â
Removed the control,, left the bake there.
Â
Bernie Wilder
On Mon, Apr 28, 2014 at 4:43 PM, Chillyz <mypulsar3(at)gmail.com (mypulsar3(at)gmail.com)> wrote:
[quote] --> Pulsar-List message posted by: "Chillyz" <mypulsar3(at)gmail.com (mypulsar3(at)gmail.com)>
Hello Group,
Has anyone installed parking brakes on their aircraft? Â I was wondering what some of you are using? How to install and how difficult it was/is. Â I think Matco has a little hand-operated brake kit for sale at Spruce. It's a valve body with 2-inlet and 2-outlet fitting connections and an actuator arm that applies up to 1200 psi to hold the brakes. Not too familiar with the setup. Â Any help would be greatful. Â Thanks. Â Summer is almost here!!!
st" target="_blank">http://www.matronics.com/Navigator?Pulsar-List
MS -
e -
     -Matt Dralle, List Admin.
ccoulter(at)wavecable.com Guest
Posted: Tue Apr 29, 2014 7:30 am Post subject: Parking Brakes |
The manual covers this. I still have a valve as I did not
use when building.
Clarke
On Mon, 28 Apr 2014 13:43:14 -0700
"Chillyz" <mypulsar3(at)gmail.com> wrote:
Hello Group,
Un/Subscription,
Forums!
Admin.
Posted: Tue Apr 29, 2014 1:04 pm Post subject: Parking Brakes |
Hi,
I installed as well parking brake control valve when I build the plane. I control valve via control cable.
Esa
Pulsar XP
Rotax 912 UL
From: pulsarbob(at)comcast.net (pulsarbob(at)comcast.net)
Sent: ‎4/‎28/‎2014 19:35
Subject: Re: Parking Brakes
Chillz
Hello Group,
ics.com
