RV-8 flap fairing
pplous(at)aol.com
PostPosted: Sat Apr 12, 2014 12:37 pm    Post subject: RV-8 flap fairing Reply with quote
Listers,
I'm experiencing some trouble getting the flap fairing to fit. When the ailerons are in the neutral position and training edges of the flaps match that position, the flap fairing sits too low on the flap root edge to leave enough fairing metal to be riveted satisfactorily using the designated rivet holes. Moving the flap fairing up to get enough material to set rivets gives me about half an inch gap at the trailing edge of the flap fairing between that and the flap. If I move the trailing edge of the flap up 5 degrees or so, the fairing fits just fine.
Some questions:
1. I am making the gross assumption that the trailing edges of the ailerons and flaps line up when properly positioned. Is this a good assumption? Somehow I just can't see a 5 degree split being what Van had in mind.
2. Has anyone else experienced this problem, and how did you solve it?
Thanks for the help!
v/r,
P2
Preston Plous
Slowest quick-build ever
Site Admin
PostPosted: Sat Apr 12, 2014 3:23 pm    Post subject: RV-8 flap fairing Reply with quote
Are you SURE your ailerons are in the right position when neutral? Don't use the wing tips as a guide. The wing tips are generally NOT right and have to be cut and adjusted.
Recheck your aileron alignment. My RV-8 QB flap fairings fit very nicely.
Matt
At 01:35 PM 4/12/2014 Saturday, you wrote:
[quote]Listers,
Some questions:
v/r,
P2
Preston Plous
carl.froehlich(at)verizon
PostPosted: Sat Apr 12, 2014 3:54 pm    Post subject: RV-8 flap fairing Reply with quote
Preston,
If the situation is as you say and this issue is identical on both sides,
then both your flaps have a twist. I suspect this is not the issue but you
should check.
1. The flaps must fit up tight to the fuselage. Do this first. Based on
what you have said I suspect this resolves your flap fairing issue.
2. Once the flaps are tight up against the fuselage, use a straight edge on
the wing extending over the flap. Examine the gap between the straight edge
and the flap at both the inboard and outboard edges of the flap. They
should be about the same. If not the flap is twisted.
3. Assuming the flap is not twisted, then you have to find out why what you
think is aileron neutral is not what the flaps think as neutral. Here the
wing templates come in real handy to find the real aileron neural point. If
you don't have these, then use of a straight edge on the top and bottom of
the wing. With a lot of measuring and comparing will get you what you need.
Do not rely on the Van's aileron bell crank "neutral" template for this.
4. After you figure this out, first the flaps then the ailerons, then and
only then are you ready to fit the wingtip. If you already fit the wingtip
then you have some rework to do.
Carl
