Zenith701801-List:
jgswartout(at)gmail.com
PostPosted: Wed Jan 15, 2014 5:26 pm    Post subject: Zenith701801-List: Reply with quote
Hi Bill,
Not flying yet (boooo!) so can't help.  But nice to know you're around.  I don't lurk on the forums much these days, but still plugging away on the FWF.  Just had to pull the bushings out of the engine shaft flange because it's for a fixed-pitch prop, but I bought a Whirlwind prop which was designed as a constant speed but then changed to a ground-adjustable.  Needs two flush bushings and four shorter than any of the fixed pitch bushings.  Demands of work have really interfered with plane-building for the past 18 months.
Best,
John
On Wed, Jan 15, 2014 at 10:30 AM, Bill Wilcox <akkeystone(at)gmail.com (akkeystone(at)gmail.com)> wrote:
Hi
What speed does everyone else use use for best angle and best rate of climb in their 801s? I use 70 MPH for both. I could not get my airspeed to stabilize enough to get more accurate.
What about best glide speed? Longest distance and longest time. I tried 68 MPH and got a 850' drop which gives a glide ratio or 7:1. Last fall after I pulled the 801 off floats I was doing some touch and goes and it looked like I glided a lot farther at 80 MPH than 70 MPH.
Does anyone have any data to share?
Here are my calculations for glide ratio:
68mph=100ft/sec=6000ft/min
6000 ft/min / 850 ft/min= 7:1
N801BW
Bill Wilcox
Soldotna, AK summer
Casa Grande, AZ winter
The 801 is in the hanger for the winter
800 hrs with 100 on floats
I posted this question on the Zenith.aero site.  Ben, Ray and Dan answered.  Is there anyone else that flys an 801 that has experimented with this?
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
tp://forums.matronics.com
