andynfultz(at)bellsouth.n Guest
Posted: Sun Nov 17, 2013 1:49 pm Post subject: Ram Valve Adjustment |
Does anybody know what Ron recommends for the valve adjustments on his EA-81 Ram engine?
Andy F.
Sent from my iPad
| - The Matronics Stratus-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
d3dw(at)sbcglobal.net Guest
Posted: Tue Nov 19, 2013 11:22 am Post subject: Ram Valve Adjustment |
.014 all around
Andy Fultz <andynfultz(at)bellsouth.net> wrote:
Andy F.
Sent from my iPad
Posted: Wed Nov 20, 2013 10:53 am Post subject: Ram Valve Adjustment |
Not exactly. Here's the reply I got from Ron.
Andy
First of all the valve lash needs to be checked hot, the lash will be tight when cold. Also when you check the be absolutely sure that each cylinder is at TDC when checked, on that engine the one down and check the other (like on a chevy) will not work.
You might be getting some settling but you will not know by checking them cold. Set your lash, as I described, put a few hrs on it and check again, HOT!
Lash is Intake .010 Ehaust .012 hot.
Ron
Sent from my iPad
On Nov 19, 2013, at 12:17 PM, Don Walker <d3dw(at)sbcglobal.net> wrote:
Quote: |
.014 all around
> Andy F.
> Sent from my iPad
Posted: Thu Nov 21, 2013 5:17 pm Post subject: Ram Valve Adjustment |
Wow. Glad to know of the change from my prior conversations.
Andy
Ron
Sent from my iPad
> .014 all around
>> Andy F.
>> Sent from my iPad
Posted: Fri Nov 22, 2013 9:45 am Post subject: Ram Valve Adjustment |
Don,
Just to be sure, I am talking about the RAM Performance engine here and not the original Stratus. I got a Ram long block after I had a catastrophic failure of my Stratus engine one tear ago.
Andy F.
Sent from my iPad
> Andy
> Ron
> Sent from my iPad
>> .014 all around
>>> Andy F.
>>> Sent from my iPad
Posted: Fri Nov 22, 2013 3:50 pm Post subject: Ram Valve Adjustment |
Ahh, thanks, Andy, for the clarification.
Quote: |
Don,
Andy F.
Sent from my iPad
>> Andy
>> Ron
>> Sent from my iPad
>>> .014 all around
>>>> Andy F.
>>>> Sent from my iPad
