pdelano(at)telus.net Guest
Posted: Mon Nov 04, 2013 8:35 am Post subject: Rivet Squeeze and #40 blind hole locator |
Hi all,
Is it necessary to invest in a rivet squeezer and blind hole locator or do the DIY pliers and #40 hole finder (strap duplicator) work fine for the whole project? I will need them soon for trailing edge solid rivets and wing root skin.
Perry
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dougsnash
Posted: Mon Nov 04, 2013 10:00 am Post subject: Rivet Squeeze and #40 blind hole locator |
Perry, I picked up an economical rivet squeezer from one of the aviation tool supply houses(Avery I think) for a fairly reasonable price. It may work to squeeze the soft trailing edge rivets with modified pliers but for the cost, the proper tool worked so easy it was well worth the price.
I think this is the squeezer I ended up using.
http://www.averytools.com/prodinfo.asp?number=64015
Doug M
CH-701 from scratch
NW Ontario, Canada
On Monday, November 4, 2013 10:43:10 AM, Perry Delano <pdelano(at)telus.net> wrote:
Hi all,
Perry
[quote]www.mypil target="_blank" href="http://www.matronics.com/contribution">http://www" target="_blank" href="http://www.matronics.com/Navigator?Zenith70180======
Posted: Mon Nov 04, 2013 12:23 pm Post subject: Rivet Squeeze and #40 blind hole locator |
Hi Doug,
Do you have order inserts with the squeezer, or is the bare tool all you need.
Perry
Sent wirelessly from my BlackBerry device on the Bell network.
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
dougsnash
Posted: Mon Nov 04, 2013 12:32 pm Post subject: Rivet Squeeze and #40 blind hole locator |
You'll need inserts too.
Doug M
On Monday, November 4, 2013 2:31:25 PM, "pdelano(at)telus.net" <pdelano(at)telus.net> wrote:
Hi Doug,
PerrySent wirelessly from my BlackBerry device on the Bell network.
Sender: owner-zenith701801-list-server(at)matronics.com
Date: Mon, 4 Nov 2013 10:00:04 -0800 (PST)
To: zenith701801-list(at)matronics.com<zenith701801-list(at)matronics.com>
ReplyTo: zenith701801-list(at)matronics.com
Subject: Re: Rivet Squeeze and #40 blind hole locator
Perry, I picked up an economical rivet squeezer from one of t= he aviation tool supply houses(Avery I think) for a fairly reasonable price= . It may work to squeeze the soft trailing edge rivets with modified = pliers but for the cost, the proper tool worked so easy it was well worth t= he price.
http= ://www.averytools.com/prodinfo.asp?number=3D64015
Doug M
CH-701 f= rom scratch
NW Ontario, Canada
<= div dir=3D"ltr"> On Monday, November 4, 2013 = 10:43:10 AM, Perry Delano <pdelano(at)telus.net> wrote:
Hi all,
Is it necessary to invest in a rivet squeezer and blind hole loc= ator or do the DIY pliers and #40 hole finder (strap duplicator) work fine = for the whole project? I will need them soon for trailing edge solid rivets= and wing root skin.
Perry</= div>
=0A=0A Quote: | www.mypil=
target=3D"_blank" href=3D"http://www.matronics.com/contribution">http://ww=
w" target=3D"_blank" href=3D"http://www.matronics.com/Navigator?Zenith70180=
=3D=3D=3D=3D=3D=3D=0A |
</= div>
[/b][b]
ronlee
Posted: Tue Nov 05, 2013 11:48 am Post subject: Re: Rivet Squeeze and #40 blind hole locator |
I couldn't squeeze mine by hand and make them look decent. If they don't look nice it will reflect on the quality look of your airplane.
_________________ Ron Lee
Tucson, Arizona |
roger(at)nwtradingpost.co Guest
Posted: Tue Nov 05, 2013 11:58 am Post subject: Rivet Squeeze and #40 blind hole locator |
I had the same experience: it is definitely worthwhile to make the
investment!
Roger Venables
Kenmore, Washington
Posted: Tue Nov 05, 2013 5:04 pm Post subject: Rivet Squeeze and #40 blind hole locator |
Hi Doug,Roger,Ron,
Looks like there will be a rivet squeezer in my Christmas Stocking. Thanks all for your advice.
Perry
