Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Sat Jun 22, 2013 3:16 pm Post subject: Spark Plug question |
I've always used NGK BR8ES plugs (solid cap) on both my 503 and 582 engines.
Today a friend showed me NGK BR8EIX (solid cap) plugs which he's just started using. NGK claims that this Iridium fine wire plug causes smoother idling, faster spark resulting in quicker engine starts, and less fouling. He's used it for about 5 hours in his 582 and says that the claims are justified. The plugs are twice as expensive as the BR8ES, but have a longer
life. (Just how much longer he didn't know.)
Do any of you have experience with these plugs, and what's your verdict?
Arty Trost
Sandy, Oregon
www.LessonsFromTheEdge.com/uladventure2009.htm
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
rickofudall
Posted: Sat Jun 22, 2013 6:11 pm Post subject: Spark Plug question |
I have to run Iridium plugs in my HKS. They last over 200 hours and come preset at the right gap. For the 582 consider that Iridium is brittle and you will need to close the gap down to .016/.018 for the 582 ignition to fire it efficiently (it comes set at .036 or so). One tap too many and you get to buy another twice as expensive plug. Up to you, but the BR8ES works good and lasts a long time.
Rick Girard
On Sat, Jun 22, 2013 at 6:16 PM, TheWanderingWench <thewanderingwench(at)yahoo.com (thewanderingwench(at)yahoo.com)> wrote:
| Quote: | I've always used NGK BR8ES plugs (solid cap) on both my 503 and 582 engines.
Arty Trost
Sandy, Oregon
Helen Keller
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
