Zenith701801-List Digest: 1 Msgs - 06/10/13
Bruce Cruikshank
PostPosted: Tue Jun 11, 2013 7:50 am    Post subject: Zenith701801-List Digest: 1 Msgs - 06/10/13 Reply with quote
I used a 6" mill file, but rounded the edges of the file with a ScotchBrite wheel to avoid scratching in the sheet around the holes. Very fast, and does not remove valuable bearing area in the holes in thin sheet.
Bruce CH750
On Tue, Jun 11, 2013 at 12:00 AM, Zenith701801-List Digest Server <zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)> wrote:
[quote]*
Today's complete Zenith701801-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Zenith701801-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2013-06-10&Archive=Zenith701801
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2013-06-10&Archive=Zenith701801
                           Zenith701801-List Digest Archive
                     Total Messages Posted Mon 06/10/13: 1
Today's Message Index:
     1. 03:46 AM - Re: Deburring ribs, spar, channels and wing skins RW  (MacDonald Doug)
________________________________  Message 1  _____________________________________
Time: 03:46:52 AM PST US
From: MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
Subject: Re: Deburring ribs, spar, channels and wing skins RW
Perry, burrs are a sharp edge and provide a point which could become a stre
ss riser and potentially lead to a crack.=C2- In other words, get rid of
them all.=C2- I am a bit obsessive about eliminating burrs and sharp edge
s=C2-on my projects.=C2- Fortunately, the 6061T6 which Zenith planes ar
e made from is fairly easy to eliminate burrs.=C2- Rather than using the
time consuming method of going over every hole with a larger drill bit or w
ith a de-burring tool, you can easily de-burr using a file.=C2- I found a
 nice little vixen file at Princess Auto in their autobody department.=C2
-=C2-The file=C2-is about a one inch square of file blade attached to
 a small wooden block.=C2- The file's intent is for removing small lumps
in automotive body filler but is works great on aluminum.=C2- I also used
 a six inch fairly fine file to clean up the edges of the parts.=C2- Basi
cally, when the part is de-burred acceptably, you should be able to run you
r bare hand over any portion of the part
 and not get cut.=0A=C2-=0AHope this helps=0A=C2-=0ADoug MacDonald=0ACH
-701 from scratch=0ANW Ontario, Canada=0A=C2- =0A=0A_____________________
___________=0A From: Perry Delano <pdelano(at)telus.net (pdelano(at)telus.net)>=0ATo: zenith701801-li
st(at)matronics.com (st(at)matronics.com) =0ASent: Sunday, June 9, 2013 11:54:00 PM=0ASubject: Zenit
h701801-List: Deburring ribs, spar, channels and wing skins RW=0A  =0A=0A
=0AHi all,=0A=C2-=0AIs there a rule of thumb for deburring on a CH-701. I
s a vixen file the best, flat file or should one go lightly with a counters
ink bit or large drill bit. Is it enough to do under the factory head and b
etween mating surfaces or does one have to remove the burrs from every side
, even where the shop head of the rivet will contact. The building standard
s say to ensure not to counter sink holes and a flat file may pull material
 into the hole but I don=99t believe it describes how best to do this
 work. I have done all the drilling on the upper and lower wing skins for t
he right wing and started deburring when I thought, I=99d better see
what others on the list have done.=0A=C2-=0ARegards,=0A=C2-=0APerry =0A
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
http://forums.matronics.com
le, List Admin.
raymondj(at)frontiernet.n
PostPosted: Tue Jun 11, 2013 8:26 am    Post subject: Zenith701801-List Digest: 1 Msgs - 06/10/13 Reply with quote
I did the same thing with a vixen file. Broke off a piece about 3" long and ground off all the corners. As I recall, that's what was used in the rudder workshop.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 06/11/2013 10:50 AM, Bruce Cruikshank wrote:
[quote] I used a 6" mill file, but rounded the edges of the file with a ScotchBrite wheel to avoid scratching in the sheet around the holes. Very fast, and does not remove valuable bearing area in the holes in thin sheet.
Bruce CH750
HTML Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-06-10&Archive=Zenith701801]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-06-10&Archive=Zenith701801[/url]
Text Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-06-10&Archive=Zenith701801]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-06-10&Archive=Zenith701801[/url]
le, List Admin.
