Nylaflow OK for Monowheel?
g-iani(at)ntlworld.com
PostPosted: Fri Jan 13, 2006 11:35 am    Post subject: Nylaflow OK for Monowheel? Reply with quote
Ron
Just got round to reading your e-mail and it night help for you to know the
following.
The black tube supplied by Europa is 6mm, not 1/4 inch. It is this size
because that is the correct size for the master cylinder fitting. The
fittings used at the wheel cylinders are the 1/4 inch (you can get them from
A/C Spruce) and they do seal with the 6mm pipe (but it is easy to pull the
tube out of the fitting).
The 1/4 Nylaflow is very good and is now standard on the finger brake
trigear which uses a different master cylinder with 1/4 connections.
I understand that it is difficult/impossible to get a good seal to the mono
and foot brake trigear master cylinder/s with the 1/4 inch tube.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
gcrowder2
PostPosted: Fri Jan 13, 2006 12:31 pm    Post subject: Nylaflow OK for Monowheel? Reply with quote
I didn't like the brake feel with the Nylaflow tubing on my monowheel.
I switched to the steel braided hose and improved the brake force
to the brake noticeably. With the Mono, you need all the brake force
you can muster!
Glenn
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: RE: Nylaflow OK for Monowheel?
Date: Fri, 13 Jan 2006 19:34:51 -0000
Ron
following.
from
mikenjulie.parkin(at)btop
PostPosted: Fri Jan 13, 2006 3:46 pm    Post subject: Nylaflow OK for Monowheel? Reply with quote
Glen,
I fitted a stick mounted master cylinder to my mono. It is really good and
has all the braking power necessary. One finger is all that is necessary.
I can recommend the stick mounted brake - the only drawback is - no brake
available to the right seat. Not a problem for me really, I don't trust
many people with my aircraft anyway.
regards,
Mike.
gcrowder2
PostPosted: Fri Jan 13, 2006 7:47 pm    Post subject: Nylaflow OK for Monowheel? Reply with quote
Hey Mike!
I also have a stick mounted brake lever with a cable going to the master
cyl on the
firewall. Maybe I would change over to the way you are doing it. Which
master cyl
and brake handle setup are you using? Thanks!
Glenn
[quote]From: "Mike Parkin" <mikenjulie.parkin(at)btopenworld.com>
Subject: Re: Nylaflow OK for Monowheel?
Date: Fri, 13 Jan 2006 23:44:55 -0000
Glen,
regards,
Mike.
scrimm
PostPosted: Fri Jan 13, 2006 8:23 pm    Post subject: Nylaflow OK for Monowheel? Reply with quote
Pictures....please
Steve Crimm
N42AH
A058
Steve Crimm
N42AH
PostPosted: Sat Jan 14, 2006 2:55 am    Post subject: Nylaflow OK for Monowheel? Reply with quote
Glen,
Contact M. Bastien at Mdoaircraft(at)aol.com
M. Bastien is French operates from Biarritz I think. His Brake
Caliper/master cylinder is first class, with built in handbrake. I am very
pleased with it. Ivan Shaw flew with the system installed, and he thought
it was excellent. They are not cheap though.
regards,
M Parkin (GJULZ)
Dan Bish
PostPosted: Sat Jan 14, 2006 11:52 am    Post subject: Nylaflow OK for Monowheel? Reply with quote
I second that request please.
Dan
Kit A144 - N914RB
Tucson, AZ, USA
[quote]--
Kit A144 - N914RB
Mono, 914F
About 40% done, CM finished, most controls, tower, tailplanes, etc. Working on wing incidence and landing gear.
