QB fuselage stand
dmaib@me.com
PostPosted: Sun Jun 04, 2006 7:54 pm    Post subject: QB fuselage stand Reply with quote
I expect delivery of my QB fuselage and wings within a couple of weeks. I have constructed a wing cradle but need some advice on the fuselage. I believe I may have seen a comment somewhere about constructing some short saw horses to set the fuselage on. I assume this would put it at a comfortable height for work. I have also looked at the rotating stands for sale by a gentleman on another forum, but it looks like it might not work until the tailcone and the fuselage are mated.
I would appreciate any information.
David Maib
Eagan, MN
David Maib
RV-10 #40559
New Smyrna Beach, FL
Deems Davis
PostPosted: Sun Jun 04, 2006 8:39 pm    Post subject: QB fuselage stand Reply with quote
Dave, here's a link to some pic's of my fuse 'stand' it's constructed
from 2 wodd saw horses and 2 8' 2x4's the original idea belongs to Rick
Sked. They's been very useful. If I had it to do over I would:
1 lower them a couple of more inches (I'm 5'6" and its a bit of a reach
for some of the tasks).
2. put bigger wheels on 9these get stuck between the lines in the garage
floor.
http://deemsrv10.com/album/Sec%2029%20Fuse%20Side%20Skins/slides/DSC02550.html
Deems Davis # 406
Fuse
David Maib
Eagan, MN
David Maib
http://forums.matronics.com/viewtopic.php?p=38593#38593
KiloPapa
PostPosted: Mon Jun 05, 2006 11:56 am    Post subject: Re: QB fuselage stand Reply with quote
Here is a pic of the stand I believe Deems was referring to.
Kevin
#40494
Pearblossom, CA
 Filesize:  35.5 KB
 Viewed:  880 Time(s)
jjessen
PostPosted: Mon Jun 05, 2006 12:35 pm    Post subject: QB fuselage stand Reply with quote
Try these wheels for your fuse cart. Get them at wood working stores, such
as Rockler.
John J
(328 - Tailcone)
 Filesize:  23.44 KB
 Viewed:  260 Time(s)
rvbuilder(at)sausen.net
PostPosted: Mon Jun 05, 2006 1:00 pm    Post subject: QB fuselage stand Reply with quote
 Oooo, Rockler.  Love the place even though it is waaaay overpriced on most things.  Save yourself some $$ and get your wheels from Harbor Freight or Northern Tool.  Worse case Lowe's-Depot.
Michael Sausen
RV-10 #352 Working on Fuselage
jjessen
PostPosted: Mon Jun 05, 2006 1:24 pm    Post subject: QB fuselage stand Reply with quote
Actually, you're right.  I saw the same wheels at HD, but forgot.  Didn't know HF had them.  Nice catch.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Monday, June 05, 2006 1:58 PM
Subject: RE: Re: QB fuselage stand
Michael Sausen
dmasys(at)cox.net
PostPosted: Mon Jun 05, 2006 3:48 pm    Post subject: QB fuselage stand Reply with quote
For the QB you may find this is lots easier than you anticipate. The QB comes with a wooden spacer for the spar that already has bolt holes in it. I just cut a couple of 2 x 4 legs with 2 inch casters and use a padded saw horse at the tail. Works great for scooting it around the shop area.
See:
http://132.239.155.44/rv10/qb_stand2.jpg
and
http://132.239.155.44/rv10/qb_stand1.jpg
-Dan Masys
#40448
David Maib
Eagan, MN
David Maib
