blanducci
Posted: Mon Oct 22, 2012 4:50 am Post subject: Propellor Choices |
Hello All,
I've been flying N168TM (Pulsar III - 912ULS) for almost ten years with the Arplast PV50. The plane is ready for a new prop. What are folks using these days with Pulsars? I must admit that the simplicity of a fixed pitch prop is appealing, but I'm afraid I may have gotten used to the in-flight adjustable's ability to optimize for climb and cruise.
During the last flight the pitch motor failed to adjust the prop pitch. This time the electric motor is spinning freely so I suspect a stripped lead screw. In past years I've had that happen one other time, plus two failed electric pitch motors. Fortuntately the failure mode is always the same - pitch is stuck where you last had it. So as long as pitch range is limited to safe flight you're okay, but it does make the cross country longer when top speed is 110mph due to engine rpm.
If anyone has old Arplast parts I'd consider buying. But something completely different might be the best solution at this point.
Bill
bernard.wilder2(at)gmail. Guest
Posted: Mon Oct 22, 2012 5:51 am Post subject: Propellor Choices |
Bill,
Love my "P" Tip. The configuration of the tip reduces prop noise. It is supposed to flex 3 degrees. Might be my imagination but when I level off and reduce power I think I can feel it flex back and take a bigger bit of air.
BUT - - - - it is fixed.
Bernie Wilder
On Mon, Oct 22, 2012 at 8:50 AM, Bill Landucci <bill.landucci(at)tds.net (bill.landucci(at)tds.net)> wrote:
[quote]--> Pulsar-List message posted by: Bill Landucci <bill.landucci(at)tds.net (bill.landucci(at)tds.net)>
Hello All,
Bill<=============
="http://www.matronics.com/Navigator?Pulsar-List" target="_blank">http:=====
http://forums.mle, List Admin.
briana(at)xtra.co.nz Guest
Posted: Mon Oct 22, 2012 10:56 am Post subject: Propellor Choices |
Hi Bill,
I also have the PV50. It's done about 460 hours now [12 years old] and I have been wondering about the life. I remember reading in some of the early Arplast documentation [ - - very limited] that the nominal life was 500 hours. It's a great prop, and I agree about the performance improvements being able to adjust the pitch in flight.
Some time ago I also had a motor failure. The motor just wouldn't start and move in one direction. I talked to Arplast and they sold me an "improved" motor. No troubles since. Each annual I open the prop hub, clean out any hardened grease and re-grease. In fact I did that yesterday, and checked the operation. All is OK. The new motor was supplied with the lead screw and bearing. The old bearing was a bit rough and lumpy too. In the meantime I had purchased a replacement bearing locally anyhow. It is a standard [metric] size and was easy to find.
I can't imagine the lead screw stripping. It is fairly substantial.
I was about to write an email to Arplast to ask about the life, and any particular maintenance that might be necessary. If I need to think about a new prop I would still think seriously about the Arplast again.
Brian
On 23/10/2012, at 1:50 AM, Bill Landucci <bill.landucci(at)tds.net> wrote:
Hello All,
Bill
freedom4life(at)xtra.co.n Guest
Posted: Mon Oct 22, 2012 12:01 pm Post subject: Propellor Choices |
Hi Bill
I have been using a Constant Speed Airmaster Prop for the last 1500 hrs on
my Pulsar XP. In the circle of friends that I fly with more than 15 run this
same propeller. I have not had to do anything to it other than replace
brushes. It transformed my plane and I wouldn't replace it with anything
else. The controller is simple to use and brilliant. There are others in
the group running this prop so it would be good to hear their experience
too. I'm not an agent for these but I certainly endorse them.
http://www.airmasterpropellers.com/
Cliff
Hello All,
Bill
barrynorman(at)comcast.ne Guest
Posted: Mon Oct 22, 2012 12:59 pm Post subject: Propellor Choices |
I have the GSC Inflight adjustable prop and it's been great for 7 years and 550+ hours. Performance is also great at a third of the cost at only 8.5 pounds.
I believe every Pulsar that has won the old races at Sun and fun had one on it.
Does anyone have results on testing/experience between all these props?
To: "pulsar-list" <pulsar-list(at)matronics.com>
Sent: Monday, October 22, 2012 8:50:02 AM
Subject: Propellor Choices
--> Pulsar-List message posted by: Bill Landucci <bill.landucci(at)tds.net>
Hello All,
If anyone has old Arplast parts I'd consider buying. But something completely different might be the best solution at this pobsp; - List Contribution Web Site -
_p; &n====================
otto(at)otamat.com Guest
Posted: Mon Oct 22, 2012 11:05 pm Post subject: Propellor Choices |
Have look at www.Ivoprop.com I have on Rx914 Ivoprop Magnum 2 blade
high pitch electric pitch adjustable, but forget their CS box - no
good.
otto
OK NUZ-20
Pulsar III
Rotax 914
On 22 October 2012 22:58, <barrynorman(at)comcast.net> wrote:
| Quote: | I have the GSC Inflight adjustable prop and it's been great for 7 years and
pounds.
it.
Hello All,
Otto Souta
kdpalmer(at)mweb.co.za Guest
Posted: Tue Oct 23, 2012 8:13 am Post subject: Propellor Choices |
Unfortunately GSC no longer manufacture the in flight adjustable.
Posted: Tue Oct 23, 2012 4:00 pm Post subject: Propellor Choices |
I was on thier website last night and they still advertise it. Where did you hear they no longer produce it?
Barry
Sent: Tuesday, October 23, 2012 12:12:10 PM
Subject: Re: Propellor Choices
 P { MARGIN: 0px } Unfortunately GSC no longer manufacture the in flight adjustable.
Posted: Tue Oct 23, 2012 6:20 pm Post subject: Propellor Choices |
I am sure they advised me by email a few years ago saying they had discontinued them, when I was checking something, I had two in flight adjustable GSC props, I was very surprised at the news ??.
pilot623(at)gmail.com Guest
Posted: Thu Oct 25, 2012 8:18 am Post subject: Propellor Choices |
I have to agree with Cliff. My Airmaster CS prop has been in use about 140
hours and as he says, it's simple to use in all phases of flight. I have not
had any maintenance issues. It's a bit heavier than most and certainly more
expensive but I love it and would buy it again. My previous experience was
with the Ivo in-flight adjustable. It worked fine but I did suffer a few
maintenance issues like replacing the internal drive motor twice. I'm no
aerodynamicist but the shape of the blades had me wondering if there were
some more efficiencies that could be had there. I've never operated my plane
with a fixed pitch prop.
Jim Fillman
N623JF
Series 2
Rotax 912S
Posted: Thu Oct 25, 2012 12:56 pm Post subject: Propellor Choices |
Jim,
What prop did you have before? Did you get the 2 or three blade version? Was there in improvement in performance over the old one?
Barry
Sent: Thursday, October 25, 2012 12:17:53 PM
Subject: RE: Propellor Choices
--> Pulsar-List message posted by: "pilot623" <pilot623(at)gmail.com>
Jim Fillman
N623JF
Series 2
Rotax 912S
Posted: Thu Oct 25, 2012 1:34 pm Post subject: Propellor Choices |
Hi Barry,
I used the 3 blade Ivo medium before. The Airmaster is 3 blade as well and uses Warp blades. I like the inlaid nickel leading edges but here in Houston, have to keep a light coat of oil or grease on the nickel to avoid corrosion. I have seen around 5 mph improvement with the Airmaster. It is fully feathering but I haven't feathered it in flight. Something about killing a perfectly happy engine in flight bothers me.
A rotating switch is used to select the Takeoff (5,800 rpm), Climb (5,500) or Cruise (5,000) setting. There a Hold setting so you can select your rpm if you don't want to use one of the standard settings. There is also a Manual mode where you then use a toggle switch to increase or decrease pitch. This prop only consumes an amp or two vs. the Ivo which consumes more as it nears the stops, up to 10 amps or so. The Ivo achieves different pitch settings by warping the blades rather than rotating them in the hub.
Jim
[quote] From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of barrynorman(at)comcast.net
Sent: Thursday, October 25, 2012 3:56 PM
Subject: Re: Pulsar-List: Propellor Choices
Jim,
Barry
Jim Fillman
N623JF
Series 2
Rotax 912S
-----Original Message-----
[mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of freedom4life
Sent: Monday, October 22, 2012 3:01 PM
--> Pulsar-List message posted by: "freedom4life"
--> <freedom4life(at)xtra.co.nz>
Hi Bill
Cliff
Hello All,
Bill
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Posted: Thu Oct 25, 2012 3:35 pm Post subject: Propellor Choices |
Jim,
Thanks for the info. Is there an advantage to a three blade vs two blade?
Barry
Sent: Thursday, October 25, 2012 5:34:15 PM
P { MARGIN: 0px } Hi Barry,
Jim
Jim,
Barry
Jim Fillman
N623JF
Series 2
Rotax 912S
Posted: Thu Oct 25, 2012 9:50 pm Post subject: Propellor Choices |
Barry,
There is a stack of information on the net about props it becomes a very interesting subject once you get started, and one thing least known about by most pilots, you must have heard the phrase "There are horses for courses"
Good reading
Keith
Posted: Fri Oct 26, 2012 5:28 am Post subject: Propellor Choices |
Barry,
I've always heard that 3 blades are better for takeoff and climb but worse for cruise speed than 2 blades. I believe this holds true for fixed pitch. In a constant speed setup, I believe there are still probably some penalties associated with more blades during cruise. This is all just my opinion and I'm only an expert on my opinion.
Cliff made an important point in an earlier post about the braking ability when the prop flattens out. Before I started flying a Pulsar, I heard many comments about how hard it could be to get it slowed down for landing but I've never had any problem in that respect. Of course I've always flown mine with 3 blades and the ability to flatten out the prop for landing. Lastly, I've always thought 3 blades looked better on a plane.
I have no experience with the GSC in-flight adjustable and only a few hours behind an Arplast in Tim Rupp's plane. I looked at the Whirlwind but it required a conventional governor and was quite expensive compared to Arplast and Ivo at the time. I strongly considered the Arplast before choosing an Ivo when originally launching my Pulsar. I liked the Arplast better but was afraid of the fact they were in France and didn't have a solid support structure in the USA. Bernie Berger and I bought Ivos at the same time (his was 2 blade magnum for the 914) and negotiated a "volume" discount. And then for my fire rebuild I bought the Airmaster from New Zealand, go figure. At least they spoke my language even if their measurements were all weird.
Hope this provides some insight, at least from my expert opinion.
Jim
N623JF
Rotax 912S
Airmaster AP332 constant speed 3 blade
Sent: Thursday, October 25, 2012 6:29 PM
Jim,
Barry
Jim
Jim,
Barry
Jim Fillman
N623JF
Series 2
Rotax 912S
Posted: Fri Oct 26, 2012 7:28 am Post subject: Propellor Choices |
Thanks for all the info. Sounds like it comes down to where you want your performance much like gearing a race car. I like mine in cruise because I take a lot of long trips.
Jim, I finally mounted the RV front wheel pant on the Pulsar like yours. Looks good and makes maintenance much easier.
Barry
Sent: Friday, October 26, 2012 9:27:58
P { MARGIN: 0px } Barry,
Jim
N623JF
Rotax 912S
Jim,
Barry
Jim
Jim,
Barry
Jim Fillman
N623JF
Series 2
Rotax 912S
