Rocker arm adjusting screw.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
tshankland(at)sbcglobal.n
PostPosted: Mon Oct 08, 2012 12:14 pm    Post subject: Rocker arm adjusting screw. Reply with quote
I'm just doing the annual on my 601HD with A Stratus engine. I found that one of the adjusting screws had broke inside of the rocker arm. Everything looks OK but I am having some difficulty in locating either the adjusting screw or another rocker arm. Does anybody have any leads?
Tim Shankland N706TS Zenith 601HD
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
larrycmcfarland(at)gmail.
PostPosted: Mon Oct 08, 2012 1:01 pm    Post subject: Rocker arm adjusting screw. Reply with quote
Hi Tim,
I’d go to your local Subaru dealer parts department.
I’ve had a lot of luck with my Subaru parts there.
Larry McFarland
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Tim
Sent: Monday, October 08, 2012 3:14 PM
To: stratus-list(at)matronics.com
Subject: Rocker arm adjusting screw.
andynfultz(at)bellsouth.n
PostPosted: Mon Oct 08, 2012 6:30 pm    Post subject: Rocker arm adjusting screw. Reply with quote
Tim,
Let me know if you don't have any luck getting new parts. I have two salvage yard engines that I can rob a few parts for ya if needed.
Andy F.
andynfultz(at)bellsouth.net
[quote] --
PostPosted: Fri Oct 12, 2012 12:55 pm    Post subject: Rocker arm adjusting screw. Reply with quote
Andy,
Thanks for the offer, I tried what Larry McFarland suggested and called the dealer, surprisingly they didn't think I was crazy. I have found the a 1986 to 1989 DL seems to be the right car for parts. My new adjusting screw will be here Tuesday for only $4.05. I was supprised I didn't have to buy a valve train assembly to get one part as is often the case. There were 11 new screws left in the country, now there will be 10.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
