Fixing case threads
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
jpkarnes
PostPosted: Mon Aug 20, 2012 4:27 pm    Post subject: Fixing case threads Reply with quote
Hi all,
After having my heads reworked by RAM, I tried to tighten the nuts to proper torq and the stud backed out (on #3 on the right side). I drilled it out and put a helicoil in its place but ran into the same problem. I was getting pretty nervous about this time for fear that I screwed the pooch. Time-sert to the rescue! Because it was already oversized, I moved up to the Big-sert and with baited breath attached the head with proper torqs. No problem! Will keep you informed as to the long term success of the repair. Can't recommend Time-sert and it's big cousin Big-sert too highly!
John Karnes
Suquamish, WA
Zenith 601 HDS
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
larrycmcfarland(at)gmail.
PostPosted: Mon Aug 20, 2012 5:41 pm    Post subject: Fixing case threads Reply with quote
I did the same thing and never had any problems.  Some use these as a better alternate to cast threads.
You’ll not have any problems either.
Larry McFarland
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of jpkarnes(at)comcast.net
Sent: Monday, August 20, 2012 7:27 PM
To: stratus-list(at)matronics.com
Subject: Fixing case threads
Hi all,
John Karnes
Suquamish, WA
Zenith 601 HDS
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
